what headliner?
what headliner?
i need a new headliner, as the fiberboard or whatever was factory in my 91 needs some work. the guys who put the cage in last week tore up the back half so it has to be replaced. looking for some suggestions of how to replace it, either with similar board or the plastic version. any suggestions of what material to use as far as either of the two and where to get it would be nice. i've done some searching, but there hasn't really been much said on this question.
i'm recovering in suede, not sure if that matters...
thanks.
thanks.
the car is a coupe, did they have those factory or was it something that was just designed for it by companies? i just want to make sure it will look factory as far as the shape of it. can you recommend where to get it, i have called a few places and they have been out?
Car: 1999 Z28
Transmission: A4
http://www.1aauto.com/1A/headliners/...HL00267/130824
there you are jeff, ABS plastic.....covered in capret.
thank you. just out of curiosity the one pictured has an indentation in the center. my headliner was completely flat. is this normal? i want a nice, flat one. i could rework it if needed but just curious if they are all like this?
the i've read that they also come rolled up in a box? sounds a bit odd for plastic, is it that thin?
thanks.
thanks.
Car: 1999 Z28
Transmission: A4
Um, I am not sure as I do not have a hardtop, nor a headliner from there. My buddy has a t top headliner, and I will check the abs on his. Maybe you could call these guys and ask them? I would feel bad if you ordered it and wasnt up to your expectations, as your cars NEVER dissappoint.
goodluck.
goodluck.
i'll call them, i tried yearone with no luck and a few of the other thirdgen resources but not this one so we'll see. i appreciate it.
if anyone else has any suggestions please feel free. thanks.
I think an ABS headliner would be the best solution... I have never had my hands on one yet but from the pics I've seen they look like a decent piece. The only trick will be getting it in with the roll cage installed.... I had a hell of a time doing mine.
Car: 92' B4C Camaro
Transmission: G-Force T5
I ordered mine from Hawks. Very nice piece, and it was rolled up.
The only issue I had was the rolled up part. They used tape to keep it rolled up inside the box it was shipped in and the tape caused the plastic to have a bend on the front lip. I bent the plastic in the oppisite direction for several days, but it never came out. Anyone thats gets in my car doesn't even notice it, but the fact that you know it's there annoys the hell out of you.
anyone that has one for a coupe model?
i'd like to know if they are all like the link above with the indentations in the roof where the dome light is or if that's just 1aauto.com's?
Car: 1986 z28 and 1997 Disco
Engine: Lg4 305
Im not trying to bug you but I'm suprised that with your great work on your car you never replace the headliner. I mean that car was sweet, it had a mint interior.
Car: 88' Iroc-Z
Engine: LQ9
he sold that car
can't wait to see the new one though Jeff I think this is the cheapest place that i seen that had the boards. I know price isn't your thing, but I think all the ABS ones have the raised center. That's why i was asking if the center console still fit right. I'm figuring where it's thinner it sits alot closer to the roof than the original but still has to go across the center roof support beam. This is the cheapest place to get that i found i haven't ordered yet though. But i guess if you don't like it your not out $250 and some odd dollars instead just $130 or so but it all depends if you want it covered or want to cover it yourself.
can't wait to see the new one though Jeff I think this is the cheapest place that i seen that had the boards. I know price isn't your thing, but I think all the ABS ones have the raised center. That's why i was asking if the center console still fit right. I'm figuring where it's thinner it sits alot closer to the roof than the original but still has to go across the center roof support beam. This is the cheapest place to get that i found i haven't ordered yet though. But i guess if you don't like it your not out $250 and some odd dollars instead just $130 or so but it all depends if you want it covered or want to cover it yourself. Originally posted by Yossarian14
it happens.
Originally posted by 87CIZ
he sold that car
he sold that car
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
