No Keys. Need To Open Rear Hatch
Old Apr 9, 2005 | 02:12 PM
MrCamaro69's Avatar
Car: latest toy 79 Grand Am with 87 IROC drivetrain
Engine: 350TPI
Transmission: auto
On a 87 Firebird, How can I get rear hatch open without keys and without power? Some kid wants the spoiler off my parts car. Can the spoiler be removed from inside the car? I may let him pull it if he don't mind laying in the rat turds..Thanks.
Old Apr 9, 2005 | 02:17 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Not an easy thing to do the way you would like to.. Does the car have a power hatch release?? If so, just get it some power to it and as long as it works, your good to go.....
Old Apr 9, 2005 | 02:22 PM
MrCamaro69's Avatar
Engine: 350TPI
Transmission: auto
The dash is out of it, so no power.. I'd have to splice into the elec. hatch release someplace toward the rear of the car if it could just be shorted to make it release. I hear it's possible to have a key made from VIN# at dealer, is that true? I was hoping for another way tho if possible.
EDIT: I pulled the drivers side interior quarter panel trim, there's a small wiring harness coming out from under the door sill going to the back of the car. Is this the hatch release power wires?
Old Apr 9, 2005 | 03:10 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Yes you can get a key cut by the VIN, but some shops want to see that you are infact the owner of the car. You should be able to give power right to the hatch release switch to get it open mind you.
Old Apr 9, 2005 | 03:15 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Crawl back into the hatch area. Remove the hatch light. You should see a 10mm screw. Remove it and the manual or solenoid hatch release will come free. Behind it is a large square hole (see the image I've attached). Inside that hole is the tang that the manual or solenoid release actuates. Pry it counter-clockwise with a long screwdriver and the latch will release.
Lon
Old Apr 9, 2005 | 03:29 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have a more effective way to do it. take a long flat bladed screwdriver and a medium sized hammer. place the screwdriver on the lock where the key would be and hit it with the hammer, it will punch the lock mechanism into the car and the hatch will open. if not you can sometimes turn the screwdriver once it is lodged into the cylinder and open the hatch this way.
Old Apr 9, 2005 | 03:41 PM
MrCamaro69's Avatar
Engine: 350TPI
Transmission: auto
I'll give Lon's advice a shot, I don't want to destroy the lock just yet...Not until I get all the interior out of the car. Trying to keep it weather tight till then. Too many of these cars are disappearing so I'd like to salvage as much as possible.
BUT, Like Jesse James said before he destroyed a 70 big block El Camino into a figure 8 racer.."I'm making the rest of the El Camino's more valuable because now there's one less and they're even more rare."
Thanks for all the speedy replies folks.
Old Apr 9, 2005 | 04:29 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I agree with the removing light procedure. I did it in a JY once...but....do not do it in the sun or without something covering the glass! That glass will reflect/intensify the suns rays........ and it will burn you real good! Really really nasty sun burn......
Old Apr 11, 2005 | 07:39 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
thanks. you just saved me from typing this.
very good info.
use a good bit of force, just dont hit your hand when the screwdriver falls threw.
hammer>thumb
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
