Auto Dimming Rear View Mirror Repair
Old Apr 19, 2005 | 10:34 PM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
I have an auto dimming mirror in my '88 GTA. The mirror itself is cracked but the rest of the mirror and housing looks good. Is there anyway to have the mirror glass replaced? These are not the easiest to find so I am open to any suggestions. Thanks.
Old Apr 20, 2005 | 07:39 PM
tagta1's Avatar
I repaired one of those.Not the mirror part but the mechanical part.Had to replace those little drive belts that get worn and loose.I believe you could replace just the mirror part.The trick is really to get the mirror apart to begin with.The plastic case snaps apart and getting it seperated without breaking it is a real trick.I think it is the same size mirror as a normal rearview mirror so if you could get it out cleanly(it has to be glued in somehow to the mechanical moving part) you could just reglue the new one in place of the broken one.It can be done if you are good at improvising and are patient and careful.Those mirrors are seriously cool and the amazing part is aside from being ridiculously overcomplicated they actually work like a charm.Remember to clean the little optical sensor windows when you have it apart,and put a touch of light grease on the worm gears.
Old Apr 20, 2005 | 08:04 PM
Bunker82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TH-350
If you are not concerned with keeping it 100% original, then get a Gentex mirror. There aren't any moving parts and as long as you don't want the ones with a compass and outside temp display, they can be had for cheap on eBay. Just an idea, sorry I don't have any info concerning your specific question.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
89FormulaMan
Aug 10, 2015 10:01 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
