hawk's three piece air dam
Old May 3, 2005 | 01:38 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i don't have an air dam on my car right now, which is the reason for nor driving it right now since i live in texas. i know that it prevents overheating, but i was under the impression that it was one piece. at hawks, it's a three piece set up. how does that work?
http://www.hawksthirdgenparts.com/air_dams
Old May 3, 2005 | 02:04 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
ill take this one , the stock one was a rubbler like 1 piece one and the new ones are a hard plastic and 3 pieces. It just bolts in . Only took like 10 min to install if that . very easy to do .And it sounds awesome when it scrapes the ground since its hard plastic .
Old May 3, 2005 | 02:13 PM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I believe (though may be wrong) that the 1 piece is for Firebirds without the TA ground effects package. Mine is an '86 TA with the 3 piece one pictured. The two smaller pieces connect to the sides of the longer piece under the larger TA front bumper cover (which blocks more air from the radiator than the Firebird bumper does, hence the bigger dam).
My friend's TA had this same three piece plastic dam stock back in '87, so I assumed it was stock on my '86 too. I remember because we replaced it in auto shop class after he broke it running over a racoon...
Old May 3, 2005 | 05:48 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
my 85 trans am only had a 1 big piece that curved around . But as many people know 85 was a wierd year .
Old May 3, 2005 | 11:52 PM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the info...looks like i'm going to have to rig something up to hold for about a week. my other means of transpertation decided to quit tonight (fuel pump). tomorrow morning, i'll be cruzin' the bird again...with some sort of temporary air dam.
Old May 4, 2005 | 01:12 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
My '89 GTA had the 3 piece style.
Old May 4, 2005 | 11:57 AM
Alexcoqui's Avatar
Car: Trans Am "GTA"
my 88 GTA has the one pice.
Old May 4, 2005 | 12:12 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
I have a 88 GTA with a one piece too, seem to be the original... I had a 89 Firebird with a 1 piece too...
Old May 6, 2005 | 12:22 PM
eagle_eyes's Avatar
Engine: '93 LT1
my temporary solution works as long as i dont get stuck in traffic. i put a piece of cardboard where the air dam should be and i can make it to work just fine (20 miles away). before, i couldn't even go 3 miles before overheating.
Old May 6, 2005 | 02:00 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Axle/Gears: n/a
the prior owner of my car removed the air dam. he said it caused the car to overheat. i have never had aproblem with it off. i have an 86 2.8L
Old May 8, 2005 | 07:05 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
i had mine removed before i bought the car. seems to hold up im guessing since he jimmyed the fan to run constant. ive only had to replace the rad. because it rusted on the bottom on me. i got the 305
Old May 11, 2005 | 11:13 AM
eagle_eyes's Avatar
Engine: '93 LT1
got the three piece in yesterday. only took about 6 days to get here. i'll be putting it on today, and no more cardboard.
Old May 11, 2005 | 12:25 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
I doubt not having the air dam is what was causing your over- heat problem. They only work when going at higher speeds anyway. In traffic an air dam does nothing. It just captures the air and pushes it up toward the radiator, and that can only happen when the car is moving.
I have a 90 Firebird with the trans am ground effects and I have a 3 piece air dam. One side broke and was haging so I just un-bolted both sides and just left the middle.
Old May 11, 2005 | 11:14 PM
eagle_eyes's Avatar
Engine: '93 LT1
what i ment was i could start my car and drive my car to work without it overheating....the cardboard just delayed the fact that it would overheat on the highway...as long as there was no traffic, the car didn't have time to overheat, but if i got stuck in traffic, my car would naturally get hot and then overheat when i got going again. the cardboard helped delay it enough that i could make it to work.
Old May 12, 2005 | 04:42 PM
KintaroOe's Avatar
you also might check into the thermostat (might be flaky) nad also burp the coolant system ( may have some air pockets) ...just my .02
1992 Trans Am
May 10, 2023 07:19 PM
87iroctheo
Dec 4, 2016 11:47 AM
deracer
Apr 11, 2016 12:04 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
krisner89
Oct 10, 2015 06:03 AM
