Rear wheel well/hatch rust.
Old May 7, 2005 | 02:16 PM
ktacam's Avatar
Car: 85 z28
Engine: 305 tpi (I got screwed, supposed 350)
Transmission: 700r4, b&m shiftkit
When I open the hatch on my car and I look on the right where the spare tire is supposed to sit I can see the ground. On the opposite side where the storage compartment is, I look in and I see the ground. What is the best way to repair this? I was thinking about taking a die grinder and sanding it all down, taking 16 gauge sheet metal and welding the hole closed. Anyone have any suggestions? Can I weld there with the gas tank? Also grounding to the body will I get shocked being in the car or touching it? Let me know, Thanks.
Old May 7, 2005 | 04:53 PM
jojo22's Avatar
Car: 91 firebird
Engine: undecided thinking 383 stroker
Transmission: ??????????
I would drop the tank. but welding and then undercoating would be ideal. The only other way I see would be to rivet it then use seam sealer, then undercoat it but I don't think that would last as long. I guess it all depends on what kind of use you have for the car.
Old May 7, 2005 | 07:56 PM
v8nate92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 L03
Transmission: Borg-Warner WC T-5
The only way to go is to cut and patch with new metal, then prime, seal, and paint.
Old May 7, 2005 | 08:26 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
Old May 7, 2005 | 08:29 PM
Edelbrock Proformer T. B. I.
v8nate92rs, this is a little off topic but i just noticed that you are running the performer tbi manifold, do you like it? I ask because i just bought one but have yet to put it on and would like to know if it bolted up smoothly and if it gives a noticeable differnce in power. thanks,
Derek
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
B_Dubya
Aug 26, 2015 05:09 PM
kah992
Aug 19, 2015 02:55 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
