felts?
Car: 1983 Z28
Transmission: TH350
felts?
u guys know the felt things that push up on the door windows, i think there is 2 for each door. anyway on mine one on each door has gone bad so it scratches the windows a bit. i went to the yard and got some that dont look to bad but i still dont know for sure if they are any good and i want to tint my windows. is there something aftermarket that can be used? a place i can get them new? anything??? i dont want to pay for a tint job and these things scratch the heck out of them??
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
I was told they are called belt mouldings. The one on the inside is called the inner belt moulding and the one on the outside is the outer belt moulding. The outer costs about $80 for both I think from GM....but the inners are much more expensive for some reason.
Hope this helps!
Oh......JC whitnety had some outer ones specifically for the 1982 - 1992 Camaro and Firebirds at a cheaper price.
Hope this helps! Oh......JC whitnety had some outer ones specifically for the 1982 - 1992 Camaro and Firebirds at a cheaper price.
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Is this what your wanting? I ordered them from classic industries. I found out they ordered them from GM.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm guessing the same thing as pondriver... the 2 guides that are bolted to the door sheel itself (pic attached).
The inner and outer belt w'strip (windlace, etc names) have such a gap in price due to the outer is just the outer seal. The inner come pre-attached to the upper door trim (black plastic piece on the door panel). The plastic part is the added cost.
JCW w'strip..... You would be just as well off taking the equivilant amount of cash from your wallet and setting it ablaze. It's crap. Mine is in the landfill, somewhere...
Elephantismo
Feb 13, 2019 12:51 AM
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
luvofjah
Sep 26, 2015 08:28 PM
