restore t-top metal?
Old May 23, 2005 | 12:35 AM
chevyrumble83's Avatar
Car: 1983 Z28
Transmission: TH350
the metal on one of my t-tops is starting to fade, how do i restore it?
Old May 23, 2005 | 08:28 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
Same question here so i will subscribe to the post. ttt
Old May 24, 2005 | 08:56 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
I assume you are referring to the metal trim piece on the outer edge of the t-top panels? Mine are both pretty faded and since I am getting the car painted this year, I need to address this as well. At this point, I just plan on sanding/painting them unless someone posts up a better suggestion.
I have not yet tried to remove the seals on the panels, but does anyone know if they are easily removed from the glass? or are they bonded to the glass? If removeable, powdercoating may be a good option.
Old May 24, 2005 | 07:40 PM
polishdevil's Avatar
Car: 88 GTA
sand and spraypaint? did that on my old gta and it held up for 4 years while i owned the car...
Old May 24, 2005 | 08:05 PM
Gr89RS's Avatar
Car: '02 Z06
I just did mine a few weeks ago
First i just left the tops on the car and masked it all off, which was easier than i thought it would be...then i sanded with 400 grit and 320 grit in the worse spots to speed up the process...then i sprayed about 4 coats of flat black spray paint, i did it to all the ttop trim as well as the rear hatch trim...pics...shes dirty so excuse the smudges on the trim and the old weatherstripping-next on the to do list...
Old May 24, 2005 | 08:07 PM
Gr89RS's Avatar
Car: '02 Z06
Old May 24, 2005 | 08:08 PM
Gr89RS's Avatar
Car: '02 Z06
Old May 24, 2005 | 08:17 PM
Engine: 388 Carb
Axle/Gears: 4.10
You did the rear hatch as well? how did that come? Mine looks like it has some surface rust.
Old May 24, 2005 | 08:20 PM
Gr89RS's Avatar
Car: '02 Z06
It came out exactly like the ttop trim did, it looks alot better but that whole ttop area still looks crappy due to the weatherstripping
Old May 24, 2005 | 08:28 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I painted mine too.. Including the center part of the t-bar. But as far as I know those parts where originally powder coated.
Old May 24, 2005 | 08:32 PM
Gr89RS's Avatar
Car: '02 Z06
HMM i never knew that, but yeah i did the center bar as well
Old May 24, 2005 | 08:54 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Good stuff....
Old May 24, 2005 | 09:18 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You may be surprised as I was to learn that those outer pieces are not metal. They are a molded composite of some sort. I only found out when I saw one broken on an otherwise excellent t-top recently at a pick-a-part.
Lon
Old May 24, 2005 | 11:59 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
I cannibalized a t-top once to get that outer strip of weatherstripping. It's some kind of really hard plastic, not metal. The only metal on those things is the lock and pins.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Night rider327
Feb 25, 2016 09:50 AM
David Frans
Oct 31, 2015 08:12 PM
bigjay89gta
Oct 15, 2015 08:04 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
