AutoMeter Guages
Old May 23, 2005 | 02:59 PM
82Camaro355's Avatar
Car: 1982 Camaro Sport Coupe
Engine: Modded Carbed 355
Transmission: TH350
AutoMeter Guages
Will the 5" AutoMeter guages fit directly or with little modification into the large openings on the stock dash?
What size guages would fit the same way into the 3 smaller openings on the dash?
Old May 23, 2005 | 06:48 PM
BOTTLEDZ28's Avatar
Transmission: A4
your gonna have to make a custom gauge panel for the gauges. Covan Clasics make panels that they sell or like i said you can make your own. I highly doubt that any aftermarket gauge will fit perfect into a 82-89 cluster assembly
Old May 23, 2005 | 06:56 PM
Transmission: TH350
Dang, that really sucks. I dont want to have to purchase a full set of guages, since I really only need a speedometer.Any suggestons?
Old May 23, 2005 | 07:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
Do you plan on retaining the stock gauges that go work? If so, then why not look for a speedo that works that will replace your broken one? Or just swap in a newer style IROC cluster that still uses a mechanical cable driven speedo.
Old May 23, 2005 | 07:13 PM
Transmission: TH350
The only guage I need currently is the speedometer. I already have a voltage, temp and oil pressure guage mounted under the center air vents.Does the IROC speedometer have the stupid double needle setup, and does it read over 85MPH?
Old May 23, 2005 | 07:31 PM
Tonyrodz's Avatar
Transmission: auto
Old May 23, 2005 | 07:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
I think they did away with double needle speedo in 85 but dont quote me on that. You can get a speedo gauge that reads to 85, 110, 145,and 200(custom made)
sheachopper
Jul 31, 2019 11:27 AM
tmellott89
Oct 14, 2015 02:06 PM
