Preping for paint months before getting it painted?
Old Jun 6, 2005 | 12:53 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
if i'm getting the car painted in a few months (3 or so), would it be horrible for me to start preping it now? sanding it , filling in some imperfections (notibly a little scratch in the door and some rust spots i've sanded down), and spray it with spray can primer?
what should i do?
Old Jun 6, 2005 | 02:51 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wouldn't; spray can primer isn't waterproof. It'll absorb water and you'll get rust underneath the primer- that's why my car is so damn rusty.
If you want to do bodywork now, as long as you topcoat what you do (with paint or a sealer or something), it'll be okay. Just don't leave it in bare primer.
Old Jun 6, 2005 | 02:54 PM
well as it is theres a few spots where i've just sprayed primer over where i've sanded down/wire brushed surface rust off......mostly on the drivers side door........
I dont care how the car looks really, i'd just rather work on the body a little bit at a time rather than trying to get the whole thing done in a weekend or something when it comes time to have it painted.....
if i can start now, i'd be able to just clean up the prep work a little when the time comes, which will probably take MUCH less time than going through and sanding all the stuff down or whatever....
Old Jun 6, 2005 | 03:54 PM
Dark Mavis's Avatar
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
Yeah, im using a rattle can to prime mine, but im also getting painted a week after im done with the body work. I would recommend using something other than a rattle can to prime it, if its going to be holding out for some time.
Old Jun 6, 2005 | 05:56 PM
Kandied91z's Avatar
you must top coat it... then it's ok.
Old Jun 6, 2005 | 06:19 PM
top coat meaning....?
I dont have a compressor or access to one that i could use to spray with, so its pretty much gotta be rattle-can....
Old Jun 7, 2005 | 01:33 AM
Kandied91z's Avatar
you'd probably be alright with the key word "probably". if it's coated and covered though i wouldn't see why in the logical sense of it all.
andy74
Sep 3, 2015 08:41 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
neekolzun
Aug 24, 2015 04:59 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
