Dash plasic glue/epoxy
Car: 55 Chevy (the only one that counts), 80 TA, 85 TA, 87 FB
Engine: BBC, BBC, SBC, none
Transmission: M-22, TH400, TH350, none
I am modifying a dash, and am looking for the proper glue or epoxy to use on the abs plastic lower dash. Did a search, and did not find the info I was looking for. Any help would be appreciated (product names or product numbers) Thanks.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Plastic weld.Havent used it on my dash,but i have on smaller parts.Like shifter plate,aldl cover.Plus other stuff i cant remember.Im sure others sell this in larger containers.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've used plastic epoxy with very good results. I've found that it sticks so well, you usually break the plastic surrounding it when you try to separate it.
