I did a temp fix on the shock tower, now I have a question
Old Jun 11, 2005 | 01:42 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I had a mild-tempered stainless-steel bracket that my uncle made for his bronze ship's bell. About 1/16" thick/impossible to bend/ nearly impossible to cut or drill. All bends in the bracket were 90 degree welds.
I made a simple 'L' out of a bit of a bit of it. Five by eight by really thick. The short side has a big hole for the shock rubber, and butts up to the existing shock hole. The long has a hole that lines up with a hole in the same rail that also has the axle bumper. Bolt through this hole. Washer on top because the 90 degree bend was not quite appropriate. This thing seems strong. I think that it could be welded, and since the shock stud is long, a bracket of sorts can be added on the carpeted deck side.
The question: I used one of three holes on the inner wheel-well area .They reside on a rail that also has the axle bump-stop on its bottom edge. Looks like these holes are there for a different model. Does the T/A model use these holes for some sort of stiffening bracket? Must be for something good.
Thanks For Listening.
Seth
Old Jun 11, 2005 | 01:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds like the mounting holes for the swaybar end-link brackets.
Old Jun 11, 2005 | 01:51 PM
The sway-bar end-link brackets are in a different place. Close proximity, though. You can see the 3 holes, in a horizontal row, when you remove the tire. They reside a few inches above the bump-stop, but the bumper is mounted to the edge, and these holes are in the face of this structure.
I need another shower.
Seth
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
