Boyd Coddington Wheels
Old Jun 15, 2005 | 06:40 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I put my Boyd Coddington wheels on today and the front is sitting really high. What would be the best springs to get this car where it need to be the Eibach Pro or Sportsline??????
18X8 Front w/ 245/40-18 Nitto 555 Extreme
18X10 Rear w/285/35-18 Nitto 555R Drag Raial
Old Jun 15, 2005 | 06:41 PM
DTL504's Avatar
Old Jun 15, 2005 | 06:43 PM
DTL504's Avatar
Old Jun 15, 2005 | 06:44 PM
DTL504's Avatar
Old Jun 15, 2005 | 06:45 PM
DTL504's Avatar
Its Raining...
Old Jun 15, 2005 | 08:07 PM
Camaroguy18's Avatar
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
good *** I hope a jack is under the front on that pic .....same wheels, with the prokit
Old Jun 15, 2005 | 08:35 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
is that he correct tire size? man is it small on there.....
pro kit is nice for a raked stance and so so ride. sportline is good for that slammed look and hard ride.
nice looking rims, just chcek you tires size it seem small. i have 245 45 17 frt so if i remember right it should be a 255 35 18
and 285 40 17 rear and 295 35 18 but i could be way off.
jeff
Old Jun 15, 2005 | 10:19 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Have you moved the car since you set it down off of the jack??? On the second to last pic looks like the suspension hasn't settled yet. If you haven't moved it yet, back it up a few feet and then check it, It should lower it a bit as the suspension settles. If you have then you need to get lowering springs.
Old Jun 15, 2005 | 10:52 PM
Kandied91z's Avatar
your tire size is right. just need some springs. depending on how you drive i'd go 2" drop with bilstein sports or the pro-kit with bilstein hd's. the tires do look very thin though for the stated profile.
Old Jun 15, 2005 | 11:04 PM
DTL504's Avatar
I have NOT move the car since adding the wheels. I will look into some springs. Maybe it will settle down in a few day.... BTW all the parts on the front end is new except the springs....
Old Jun 15, 2005 | 11:53 PM
92droptop's Avatar
Car: 1992 Camaro RS Convertible
Engine: 3.1
did you index your springs in the front?? cause if you don't have the spring end covering one of the drain holes and the other end exposed, it could be causing a little bit of the extra height you're experiencing.
Old Jun 16, 2005 | 12:47 AM
johnyIROC's Avatar
Stupid question but is there an engine in the car?
Old Jun 16, 2005 | 12:50 AM
DTL504's Avatar
Damn, I forgot to put the engine in the car....
so that's why she is sitting so high.
The engine in the signature is sitting in the car.....
Old Jun 16, 2005 | 12:53 AM
johnyIROC's Avatar
lol ya never know.... with these thirdgen guys lol
We've got a candy thirdgen with boyds as well... this is getting out of control. What is your paint?
Old Jun 16, 2005 | 01:00 AM
DTL504's Avatar
My paint is the same as my Lincoln Navigator: Laser Red E-9
Old Jun 16, 2005 | 01:18 AM
johnyIROC's Avatar
Nice... If memory serves me... Laser Red was the first factory production candy.... is it a metallic red basecoat with a translucent red mid/clear coat?
Old Jun 16, 2005 | 02:46 AM
semiller26's Avatar
Car: 1986 Trans Am
wow that is insane! what did it look like before?
Perhaps the spring index was off when you put the front suspension back together? Thats the only thig I can think of but the back seems a little to high too? That is really strange.
Old Jun 16, 2005 | 12:50 PM
AaronIROCZ's Avatar
If you move it it might settle about a inch or so, but either way I think you would need springs either way.
Old Jun 16, 2005 | 01:00 PM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
What are the offsets' on the rims? .. if you dont mind me asking, what was the total for the rim and rubber? .. where did you get them from?
Old Jun 16, 2005 | 02:14 PM
CrazyHawaiian's Avatar
Car: too many ...
I agree that you need to modify the ride height. The car isn't actually sitting any higher, its just that the much smaller sidewall of the tires gives it the illusion that it was raised higher. To bring it back to the fender to tire aspect ratio you are used to you will need to lower the car. 245/40/18 and 245/50/16 are very very close. Here's a pic of my Boyds, 18x8 front with 245/40/18 and some suspension work:
Old Jun 16, 2005 | 07:54 PM
DTL504's Avatar
The rims was bought from Truck Shop and the tires come from www.discounttiresdirect.
$1680.00 Wheels
$792.00 Tires
Offset: 4.5 Front and 6.0 Rear.
Old Jun 16, 2005 | 08:02 PM
DTL504's Avatar
What suspension work was done to your car? Springs/Shocks...
I'm using KYB Gas Struts in the front....
Old Jun 17, 2005 | 01:39 AM
Kandied91z's Avatar
weight jacks... totally different ball game. well a little anyway. definately does the trick though huh?
Old Jun 17, 2005 | 01:58 AM
Car: too many ...
Yup, if you cant afford AirRide or you want to retain the OEM spring/strut setup, this is the best way to get adjustable ride height (my opinion anyway). Front suspension of this Z28 consists of Ground Control weight jacks, a SSS 10" tall 700# linear rate spring, Beltech 2 inch drop spindles and Koni Special (reds). If you want more info on the weight jacks, check out this thread.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
