Son of a B.... Have you ever burned your hand on an aluminum shifter knob?
Old Jun 23, 2005 | 10:41 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Son of a B.... Have you ever burned your hand on an aluminum shifter ****?
Holy crap! I could hardly get my car into gear with the B&M Megashifter today with temps reaching into the 90's all week so far. T-tops and Iowa's stupid no tint laws make that thing a scorcher... I swear I could boil water or cook an egg on it! That aluminum **** has got to go!!!
Has anyone else ever kicked the aluminum handle to the curb? What **** did you end up using? (searched and found some *****, but not many Megashifter ones)
Old Jun 23, 2005 | 10:49 AM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Odd, usually aluminum is more resistant to heat. For example, when I go roofing (shingling), the steel square will burn your fingers if left in direct sunlight, but the aluminum one is always cooler to the touch.
Old Jun 23, 2005 | 10:57 AM
bnoon's Avatar
Yeah, aluminum does have better heat shedding properties, but not good enough in a green house of an interior that a T-top F-body has. YOWZA!
How does carbon fiber do in the heat???
Old Jun 23, 2005 | 11:08 AM
'Shifter's Avatar
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Yep, normally I use my windshield shade and throw a rag over the
top of the steering wheel and shifter......but I forgot one day last week
I ran inside, not intending to go anywhere the rest of the day-but
something came up, and I had to leave an hour later.
I felt like Kwai Chang Kane lifting the vat full of molten metal with
his wrists, burning the dragons onto his forearms....'course mine
says Hurst......not as cool.
Old Jun 23, 2005 | 11:25 AM
bnoon's Avatar
Originally posted by M. Hall
....'course mine says Hurst......not as cool.
Depends on who you ask!
Old Jun 23, 2005 | 11:26 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
any shiny polished surface is going to be insanely hot when left in direct sunlight... so anything your going to be touching, you do not want to be shiny and polished
Old Jun 23, 2005 | 11:41 AM
CaysE's Avatar
Aluminum has excellent heat transfer properties, it is not "resistant to heat." Aluminum is used on heatsinks because it absorbs the heat quickly and then dissipates that heat into the air quickly. However, if there is nowhere for the heat to go, the aluminum will maintain that temperature. Aluminum foil is literally 400 degrees when your oven is set at 400, because there is nowhere for that heat to go. When you take it out, though, the aluminum cools very quickly to room temperature.
I wouldn't ditch that ****, because it looks great. Just keep it covered so it's not in the sun and let it cool for a moment when you get in.
Which **** is it?
Old Jun 23, 2005 | 11:49 AM
bnoon's Avatar
Originally posted by CaysE
Which **** is it?
Aluminum B&M T-handle that came with the Megashifter. I got a silver window reflective thingie, so hopefully that helps me be able to get her in gear today.
Old Jun 23, 2005 | 02:32 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I throw a hand towel on my hurst alum T handle when parked. That sucker does get hot.
Originally posted by bnoon
I got a silver window reflective thingie...
Stereo thieves sure do love those windshield sun deflectors.
Old Jun 23, 2005 | 02:38 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Here is mine. I ditched the T-Handle for a ball from the Quicksilver shifter. All aluminum and I like the looks.
Old Jun 23, 2005 | 03:07 PM
Klortho's Avatar
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Why not get the t-tops tinted, it's not the side glass and it would be no different than having a hardtop. But I agree, just grabbing my black shiftknob after the car sitting was bad today. Gonna have to toss my windshield screen back in the car.
Old Jun 23, 2005 | 03:18 PM
'Shifter's Avatar
Car: 87 Z-28
Yeah, but a Shao Lin Priest can walk through walls.....
Old Jun 23, 2005 | 04:20 PM
bnoon's Avatar
Doesn't matter, I work in a small office and my car is only 10 feet away from me all day long. Don't need the shield at home because it's in the garage there. Man, I'd love to catch someone trying though... I've been feeling like giving someone a good beating lately.
Already are tinted. Still lets in more than a hardtop. I guess I could just start growing some tomatoes in there or something as steamy as it is this week.
That doesn't help me much, but it does look cool. Aluminum is aluminum and yours would still burn my hand.
I just got back from a late lunch and boy did that sunshade help me out! I could actually go from gear to gear normally without trying to slap it from reverse to drive as fast as I could. Ahhhhhhhhhh...
Sorry for the silly cry baby post, but this is my first summer ever in almost 20 years of driving that I've ever had a car with T-tops and an aluminum shifter that tried to burn my hand off. I've had T-tops before, and I've had metal shifters before, but never in the same car so it was always managable. Future crisis averted.
Old Jun 23, 2005 | 04:53 PM
'Shifter's Avatar
Car: 87 Z-28
Man, do I have a solution for you.....
Figure out a way to make it a quick-release shifter handle, and\if you do ever catch someone trying to swipe your ride, you've got
a set of hand-fitting knucks with you!
Old Jun 24, 2005 | 05:46 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
You could always wrap it in leather, I guess. I had the same problem when I had the Megashifter in my Formula, sometimes I'd grab a glove.
Old Jun 24, 2005 | 07:36 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I actually have the same shifter **** on mine, but in black plastic instead. B&M still sells them, but the carbon fiber are discontinued as far as I know.
Old Jun 24, 2005 | 01:03 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Tint it!!! Who cares about the law. haha
Old Jun 28, 2005 | 12:21 AM
Bowtie-Bri's Avatar
Car: I have a 70 Chevelle SS, and I have an 87 Iroc Z that I just brought back too life!
Engine: 305TPI
I would keep a spare sock under the seat. Just pull it over the shifter when the car is parked. I'd make sure its clean though. You don't want too "Stink" up the interior.
Zee Ya,
Brian
Old Jun 28, 2005 | 01:45 PM
87blueracr's Avatar
Car: 1987 camaro & 70 mustang
Engine: 2.8l & built 351C
Transmission: borg warner T-5
i made a ball type for my camaro, man does that thing get hot while i am at work, i just roll the windows down before i set in the car andi always try to have it in the gear that i am gonna need to get out of the parking spot. that way i don't have to touch it more then absolutely necessary. once i get some air through the car, then it cools off to ambient temperature
Old Jun 28, 2005 | 02:07 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Transmission: Wishin Manual
Hey man i didnt know you are from iowa. I have the same shifter. go get a small hand towel and just lay it over the handle. Are you going to Josh's f-body meet?
Old Jun 28, 2005 | 02:28 PM
bnoon's Avatar
As stated, I took care of the shifter handle temp problem by using a silver reflective window shade.
You have the same shifter? Your cardomain site pics shows the Hurst dual gate shifter.
Yes, I will be going to Josh's meet. I should have quite a few parts lined up to sell for my polishing biz, so I simply can't miss it!
Old Jun 28, 2005 | 02:35 PM
stalin05's Avatar
Car: 88 IROC-Z
Engine: 350+
Lol the camaro with the hurst shifter was in my 88 305 iroc. I sold that , err, last summer. I now have a 88 350 iroc. My 305 was beautiful, but that hurst dual gate sucked. I JUST got my b&m shifter in like last week lol
Old Jun 28, 2005 | 03:32 PM
bnoon's Avatar
Ahhhh, understand now.
Old Jun 28, 2005 | 07:54 PM
Screamer27's Avatar
Car: 1986 Monte SS / 1988 Iroc-Z
Engine: LS3 / L98
Transmission: 4l80E / T56
Axle/Gears: 3.73 / 3.45
I agree with ya Brad. I drove Josh's Vette last week, (previous owner of my new car, the white WS6, best of show last year at JoshP's show) Josh has some sort of metal shift **** on his vette, and omg i swear i left skin on that stupid shifter ****, omg HOT.
Old Jun 29, 2005 | 03:56 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i didnt burn my hand but my shifter was really hot that i couldnt touch it the other day. sad part is that there is a boot that covers it but there is about a 1/2 i=of the stick exposed and it was hot
Old Jul 4, 2005 | 08:28 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i dont know if ive seen it before, but it comes to mind.
have an upholstry shop stitch leeather on it. would look similar to a trans am stock automatic shifter.
gets my vote. towels and socks hanging over the shifter is silly.
Old Jul 4, 2005 | 08:43 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I got a carbon fiber b/m one on ebay a little over a year ago for 5 bucks new. It looks pretty damn good.
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Lanz06
Sep 14, 2015 07:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
