weather stripping
Car: 98 TA
Engine: ls1
Transmission: m6
weather stripping
how much would it cost to replace all the weather stripping and rubber pieces around the doors and t-tops? Also where is a good place to buy this cheap?
thanks
thanks
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Being new.. you shal only recieve 5 replies telling you to perform a search
Seriously though, there is a w/strip post a little over half way down the forum if you scroll titled need to replace all the weatherstripping
You can use the link in my sig to find OEM numbers and check pricing.
Check the advert link to Hawks above.
A search will net you just about every answer you will most likely have about what & where to get.
I personally avoid aftermarket w'strip like the plague due to bad exp. w/it. Other's have had no complaints.
Which you choose to get generally comes down to the depth of your wallet.
edit... and now that I have regained my literacy... if this is for the 98 you have listed.. none of the above I said really applies to you... except maybe some of the advert links above.
For some reason I read 89 TA.. duh
Car: 98 TA
Engine: ls1
Transmission: m6
its not for the 98, its for a 84z.
I looked on hawks but it seemed like i would have to spend over a 1000 to just get some weather stripping.
Engine: TPI 305/ v6
SoffSeal is one of the major aftermarket companies.
Metro is another.
Here's a link to some more links... https://secure21.activehost.com/metrommp/dealers.aspx
Metro is another.
3.8TransAM
Oct 1, 2015 07:47 PM
