Help, using Ford window switch on 4th Gen Console......
Old Jul 10, 2005 | 10:17 PM
globalco's Avatar
I have I believe Ford Probe or Focus or something similar window switches for my 4th Gen console and the schematic I got is not the same. I tried wiring the switch to the wires for the 3rd Gen window and no luck but alot of heat on the wires.
Here is the wiring on the three switches I have:
1. an oblong switch with U and L markings; 1-yellow/green pin
1, 2-purple/yellow pin 5, 2-orange/black pin 2, 1 black pin 4, 2-
white/green pin 7
2. an oblong switch with U and L markings: 1-yellow pin 1,
1 orange/yellow pin 2 also 1-orange/purple pin 2, 1black pin
4, 1-orange/purple pin 5, 1-white pin 7 also 1- white/blue pin 7
3. an oblong switch with arrows pointing up and down; 1-
white/purple pin 1, 1-purple/white pin 2, 1-yellow/purple pin
3, 1-black pin 4, 1-orange/black pin 5, 1-white/purple pin 6,
1-yellow purple pin 7
The wiring gauges on the first 2 are the same I am guessing 14 and 16, the 3rd is 16 and 18.
Thanks for any help you can supply.
Jim
Old Jul 10, 2005 | 11:48 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
Ford switches, on your 4th console, hooked up to your 3rd gen wiring
this is only 1/3 thirdgen related, i refuse to help :P
besides post this in the electronics forum
Old Jul 11, 2005 | 09:15 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
#3 sounds like the pwr switch wiring from a furd contour which is what I have in my 4thgen console..
After destroying one of the 3 I bought.. this is how I wired mine. You can reverse where the + & - pwr in go but, the LED backlight won't work. The rear switches though, have 2 small 22-24ga wires seperate for the LED so you can wire them independant of how you wire the switch.
Attached Thumbnails Help, using Ford window switch on 4th Gen Console......-switch.gif
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Wylecoyote08
Aug 14, 2015 08:28 AM
