Painting the rear end?
Old Jul 12, 2005 | 11:52 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Ok, so I'm going to sand blast this spare rear I have here, and rebuild it with my HD ZT... I want to paint it, to make it look better (than rust) but am wondering what options you guys have, on a tight budget?
Old Jul 13, 2005 | 04:56 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
i'll bump for ya.. I too have a rear end ready to install that I was thinking about wire brushing and hitting with black tremclad.. perhaps someone has a better idea?
Old Jul 13, 2005 | 06:00 AM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
You could try powdercoating it, it would work better than paint I would think.
Old Jul 13, 2005 | 06:03 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
POR 15 work very well
Old Jul 13, 2005 | 06:29 AM
CrazyHawaiian's Avatar
Car: too many ...
Get the rust off, clean it up real good no more dirt/grease, tape off the brakes and hoses, and hit it with a few cans of high temp Engine Paint in your favorite color. When I re-did my suspension I took every part off and painted it, cost me $20 for all materials. Looks much better now. Por 15 would be great too. Another big appearance changer is getting the rotors turned and painting the center by the studs (hub portion) and calipers, or if its drums, painting the drums. You could make a big difference for around $20-$40.
Old Jul 13, 2005 | 09:16 AM
kyles88bird's Avatar
Car: Trans AM
Engine: 305 TBI LO3
Transmission: W/C T-5
Axle/Gears: 3.42 Open
when i was gettin the new rear ready to be swapped in(new seals and paint) all i did was wire brush it, wipe it down and spray bomb it(spray can) so far its still on there, dusty but the paint is there and still black. ill try to get some pics for u
Old Jul 13, 2005 | 08:26 PM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
F-IT
if you can wirebrush it down or sand blast it
hit it with some Rustoleum paint
i like glossy black
i've had it last years on the cars i've done
and it looks great
it's not that east to see the 3rd gen rear especially if you have the exhaust there
on my 79 TA, thats a different story, more visible
i just painted right the rear on her car, looks good considering all i did was just paint it real quick.
Old Jul 13, 2005 | 09:31 PM
onebinky's Avatar
I wire wheeled all the rust away and painted with eastwood rust encapsulator.
The little bit of discoloration all over the place is grease from my hands. I still have yet to wipe all that off
Old Jul 13, 2005 | 11:21 PM
VILeninDM's Avatar
http://www.autobodystore.com/cgi-bin...mes;read=30120
I am about to cover my rear end and entire underbody with that zero rust stuff.
Old Jul 14, 2005 | 12:39 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Here's my Rustoleum primer + paint after a wire-wheel.. Came out great.
Kevin D.
Old Jul 14, 2005 | 12:50 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
POR-15 all the way
Old Jul 14, 2005 | 04:16 AM
Brisk's Avatar
well that settles it, I'm going to have to pick up a wire wheel for my drill (grinder?) and go with that route. thanks!
Old Jul 14, 2005 | 06:43 AM
VILeninDM's Avatar
has anyone seen Chassis Saver stuff ?
My body shop really wanted me to buy it. The price (at about 50% I think) sure beats Por-15, but I did some searching on google and on entire internet the only reviews I found were marketing fluff (just because they all sound so similar), but I didn't find a single real person that has actually used it in real life on a real car.
Old Jul 14, 2005 | 09:18 PM
onebinky's Avatar
If you have the kind of scale buildup I did, a drill won't have the torque you need. I used a 4" knotted wire wheel on an electric grinder. Wear safeties and a breather mask too, you'll need em.
Old Jul 14, 2005 | 11:11 PM
Brisk's Avatar
onebinky your under carriage is impecable.. looks new.
I've got a 5" makita grinder, looks like I'll have to seek out a wire wheel for it.., thanks!
Old Jul 15, 2005 | 12:17 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
go with por-15. i have used it and it works great. just make sure you prep it first
Old Jul 15, 2005 | 10:26 PM
onebinky's Avatar
Still not completely done, but I got the hard part finished. It was covered in poorly done undercoating, had a few rotted sections that needed replacement, and alot of rust that needed to be removed. Now I just need to strip the rear frame stubs and the rocker area and paint em up. I ran out of time last year before fall really hit. It's slowly getting to where I want it to be, just a matter of time.
Oh, I'd recommend the knotted style wheel too. The regular bunched style doesn't work nearly as well for rust and scale removal, and will wear out much quicker.
Old Jul 16, 2005 | 06:47 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
Hey Vil,
My jobber that sells us our paint swears that it's every bit as good as POR 15 at half the price...
Hope this helps.
Old Jul 17, 2005 | 08:04 AM
Rabbitt's Avatar
Car: 1987 Iroc-Z
Engine: 355
Originally posted by KEVIN G.
Hey Vil,
Hope this helps.
hmmmmm... just as good? sounds good to me.. i plan on coating my floor pans (inside and out) and por-15 is soo damn expensive..
Old Jul 17, 2005 | 02:54 PM
spatter1's Avatar
Car: 89 RS
Engine: LO3
Transmission: TH700R4
Another vote for POR-15
I have used POR-15 on my rear (and a lot of other parts) and it works great. Highly recommended.
Old Jul 17, 2005 | 05:30 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
theres stuff called Rust Bullet it works really good a buddy of mine got it, you don't have to lay down all the stuff before hand for it to stick like you do the por-15 it's cheaper and supposedly better too which makes it better in my book.
Old Jul 17, 2005 | 06:24 PM
Brisk's Avatar
Well I wire wheeled my rear and sprayed it down with "rust not" just cheap stuff I found at a local auto supply store. They didn't have Tremclad, which I was going to use, and he says this stuff is the same or better.. whatever.
I sprayed the rear with 'dove gray' and didn't like the results.. a bit bright. However it did work very well as a primer. I then resprayed with black, couple good coats. I like the way it turned out. Its not a show car so it isn't perfect, couple runs and whatnot. Really our cars are so low that no one is going to see it and only I'll know its there.., its not a show car.
Now if I can only find the proper drive and driven gear for my speedometer to mate with the new 3:73 rear gears, I'll be all set. Anyone know where I can get the proper gears for a M39 Borg-Warner T-5? The dealer says they're discontinued...
Old Jul 18, 2005 | 10:38 AM
onebinky's Avatar
If you try a search on yahoo, there are a few places that carry them on the aftermarket level. Also, you can try calling around to a few dealers. Some may have old stock laying around.
Old Jul 18, 2005 | 02:29 PM
cocacolakidd's Avatar
Car: 84Z & Porsche
Engine: 427sbc - 471 - 850 Demon Claw
Transmission: Bowtie stage II TH700R4 - 10" 3000
Axle/Gears: 9 Bolt w/ 3:45's
Try Bowtie Overdrives...they deal with the 700r4 but also have a speedo gear size software chart (Tire size and gears ) to pick the different gears needed...
http://www.bowtieoverdrives.com
Old Jul 19, 2005 | 02:21 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I swear by por-15. I just stripped my engine compatment bare and preped with por15 before I primed. It does seem a little expensive but a quart seems to go a lot further than you would expect. I had painted my rear end with hammerite years ago and it never rusted through the paint but it is starting to peel. I'm pulling it out this week to make some brake brackets and I'm goign to strip it and use por 15.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
