3rd gen power windows can kiss my...
Old Jul 20, 2005 | 12:52 PM
TWICEtheRICE's Avatar
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!PITA!
If anybody wants to do this, the only way to I found to remove the assembly is to bend the crap outta the arm. As in pull it towards you. Errrrrrrrrr. Also use a stout bungee cord to hold up the window. Can't beat $25 for a new window lift and diy install though, the price was right but **** man, if I had money I would let somebody else do it.
Old Jul 20, 2005 | 01:45 PM
Okay, I am halfway done but must goto work...
Use a combination of Fast Orange, Dishsoap, and 15 min of scrubbing to remove the factory goo. This stuff is somekind of super grease that is sticky as hell and wont come off your skin.
Old Jul 20, 2005 | 02:23 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
I am not sure why everyone has such a hard time with these.
I swapped out 1 motor w/o even taking the door panel all the way off. It took 25 min. I just bent and proped the lower portion up, the panel did not want to come off)
Of course I used the easy, aka: hack, method:
https://www.thirdgen.org/techbb2/sho...dow+motor+hack
Of course if you do it this way you can't really clean and properly lube your tracks, and car's value will drop by 80%
Old Jul 20, 2005 | 04:12 PM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
GM power windows are a PITA for third gens. They are poorly designed, slow, and break down as often as you change your underwear. If I really had my choice, I would go with the good ole crank windows. They only way they break down is if your arm is broken!
Old Jul 20, 2005 | 05:39 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
i think i will try the hack job since the guy who owned the car before hacked up everything else why dont i finish the job and hack the doors up a bit. oh wait for some reason he hacked the doors up already. have no idea what he was thinking of cutting a hole by the door handle. looks like he chewed the hole with his teeth.....what an ***
Old Jul 20, 2005 | 07:22 PM
If I had to do this again, I wouldn't stress out as much. Its just something new I haven't seen before. Figuring out the tracks was a brainer, but i got it figured out now. I had to learn sometime. I can't wait to learn body work, thats going to be interesting.
Old Jul 20, 2005 | 08:06 PM
VroomVroom87Z28's Avatar
Car: 87 Z-28
Engine: 305 ci. LB9
sounds tough, but about previous owners, they suck. the guy I bought mine from thought he could paint and do body-work....he couldn't, I ended up paying over $1000 just to remove what he had done, it looked he did it with a brush and roller.
Old Jul 20, 2005 | 08:50 PM
astoria18's Avatar
Car: 1985 Trans Am
Engine: LB9
Are you replacing the motors or your entire window? I replaced both of mine and once I figured out how to do it, the work was really easy and went quickly. It's really not that much work.
Old Jul 20, 2005 | 09:17 PM
I just replaced one motor. It was my first time. The only real trick I think is the bend the lift arm to sneak the whole assembly out. I was trying to avoid bending anything for about 30 minutes of struggling and sweating my ballz off. So I said screw it and bend the bar and it came right out. Plus the grease was really nasty stuff to have on your hands, my glass is covered in that stuff from trying to reposition it. Another life saver for my loaner butt was a bungee cord to hold of the freakin window, plus it was adjustable. I should take some pics of that mess. I have yet to bolt the motor to the door tomorrow
Old Jul 20, 2005 | 09:25 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
When I installed my power windows there was no bending of anything needed...
For me the hardest part was getting those stupid rivets out. But a chizzle and a hammer fixed that problem ^_^.
You guys are right about that grease... it's a PITA...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 13, 2015 12:59 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
