dash panels foot area
Old Jul 23, 2005 | 11:45 AM
mksp89IROCZ's Avatar
Car: 86,86,89, all IROC-Zs
Engine: 305cccarb,3sumtin,305 tpi
Transmission: 700R4s
Axle/Gears: 2:73open,3:42posi,2:73posi
are the panels that fasten under the dash the same for 82-92? i know 86 and up will be the same. what about back to 82?
Old Jul 23, 2005 | 02:01 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Are you talking about the kick panels? On the sides? Or you talking about the panel on the bottom of the dash? Above your legs?
Either way, I think they are all the same.
Old Jul 23, 2005 | 03:56 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
As far as I know, the under-dash panels are the same from 82-89. I have '87 Panels in my '83 if that tells you anything.
Matt
Old Jul 24, 2005 | 09:44 AM
thanks guys. that clears everything up. i have never dealt with a third gen camaro older than 86 when it comes to working on one.
Old Jul 25, 2005 | 02:08 AM
Camaroz29's Avatar
Do you happen to know where you can get the metal clips that hold those panels in place? I've tried junkyards and everything, with no luck yet.
Old Jul 25, 2005 | 11:43 AM
Are you talking about the clips that the screws screw into?
Old Jul 25, 2005 | 04:46 PM
Camaroz29's Avatar
No, just the little clips that push right into the lower dash holding the panels that conceal the wiring in place. I think I can get some from Hawk's though.
Old Jul 25, 2005 | 04:55 PM
are you talking about the large diameter push in clips? they are about the size of a fifty cent piece? i am totally clueless.
Old Jul 25, 2005 | 05:25 PM
Camaroz29's Avatar
They are wedge shaped, black and metal. There are 2 big panels below the dash that conceal wiring, one on the drivers side and one on the passengers side. The wedge-shaped clips just push in and hold them in place. That is the best I can describe them.
Old Jul 25, 2005 | 05:30 PM
i have seen the type you are talking about. every camaro that i have seen has had screws holding the panels to the dash bottom.
Old Jul 25, 2005 | 05:45 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
82-89 screw in
90-92 clip/snap in
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Aug 14, 2015 08:25 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
