1988 GTA headlight problem
Old Jul 24, 2005 | 05:41 PM
Arnabowl's Avatar
Car: 1988 Firebird GTA Trans Am
How do you know, if the problem is bushings or the motor? My passenger headlight tries to flip up. but stuggles, and the motor keeps running for about 6-7 seconds then shuts off. I checked the drivers side. There seems to be an adjustment for the headlight as far as the opening angle should be. I noticed that it is firm and adjusts to any angle i want and holds. The passenger adjuster/ motor just spins. and I can physically open or close the headlight when the switch is on. If it is the motor can it be rebuilt?
Any other info you can provide would be very helpful. Thanks,
Arne
Old Jul 26, 2005 | 09:39 AM
Firebat's Avatar
the gears in the headlight motor are probably broke. you can take them apart and glue the gears back together. If your headlight motor spins, then the motor is good.
Old Jul 26, 2005 | 12:46 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Yep, sounds like gears. You can get a repair kit with new gears from TDS (one of our sponsors at the top of every page). That's what I did, works great!!!!!
(You're welcome, Lon)
Old Jul 26, 2005 | 12:48 PM
little P's Avatar
Car: 89 Formula
Engine: 350ci, tbi
I'm 99% sure its just the plastic pieces in the motor are eaten up. Its a cheap fix. Go to Top down solutions website.
This pic shows the dust that once was the plastic pucks that turn that nylon gear.
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 17, 2015 02:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
