steering colum problem
Old Jul 28, 2005 | 11:55 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
well i dont know if this is the right place to post this. but the other day my steering colum broke somehow. i mean i wasnt being rough with it or anything. i was just cruising down the road and made a right hand turn and now its messed up. like when i hold the wheel i can shake the whole colum from side to side. what is the problem and what can i do to fix it. all your help is appreciated guys.
Old Jul 29, 2005 | 02:26 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
I'm guessing that it's tilt column. There are 4 torx screws that need to be tightened up. But it's alot of work. And need a tilt pin puller, lock plate mover, and steering wheel puller.
Old Aug 1, 2005 | 09:56 PM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Dont be scared. It's not as hard as you might think. I had the same problem with my '88 Chevy Silverado. There are several boards around the net showing how to disassemble a GM tilt column just for this project. There used to be a really good one a guy did on a Fiero but none of the pics work. A word of advice, you DO NOT have to take the tilt mechanism out. If you get some 1/4" drive deep metric sockets you can use a 10mm to grab on to the trox bolts and tighten them through the access areas on top of the tilt shroud. I was able to get to 3 of the 4 and it makes a world of difference. My truck has been perfect for over a year with no sign of any problems. Your car probably has 100K+ miles on it and if you tighten them back down they will last 100K more. Get in there, tighten them back down, and leave it. If you try to pull the tilt section off you run a risk of breaking the tilt ujoint/ball if you try to pull it apart. Hope this helps.
http://www.gnttype.org/techarea/susp..._steering.html
http://spacecoastfieros.com/tech/stecol.htm
http://www.chevyasylum.com/column/tiltcol.html - has pics!
backtothe80s
Sep 5, 2015 12:39 AM
Oenone
Aug 29, 2015 07:54 PM
overdriv
Aug 20, 2015 03:52 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
