How do you do door skins?
Old Jul 29, 2005 | 02:12 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
How do you do a door skin start to finish? Is there a way to reatach it without welding, like with the glue that I heard they use these days?
Old Jul 29, 2005 | 02:58 PM
jovial86's Avatar
Car: 1986 Pontiac Firebird
Engine: 1991 305 TBI
Transmission: Th700-R4
JB Weld? I wouldnt. Most people just get a new door. Its a lot easier than cutting and welding. You'll also lose some structural integrity if you cut and weld I think. I'd just get a new door.
Old Jul 29, 2005 | 06:53 PM
crazycrocket's Avatar
Car: 1985 camaro
replacing a door skin should only be done with welding. I wouldn't trust glue. However this is a LONG and tedious process if you don't have the special crimping tool. It can be done though, look through the magazine racks every once in a while. Occasionally there is an article on doing door skins.
Old Jul 29, 2005 | 07:06 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i think your asking about fusor...... i used it on patch panels for my truck.. works good.
jeff
Old Jul 29, 2005 | 11:14 PM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
Good Luck finding a door skin. The aftermarket does'nt make it. I belive I got the last driver side one in the GM stock system.
Old Jul 29, 2005 | 11:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can get lower door skins.
Old Jul 29, 2005 | 11:46 PM
Snuffit's Avatar
Car: 89 formula
Transmission: t5, soon to be t56
you can get door skins for these cars, but it costs almost as much as a whole door.
And whoever mentioned fusor is right. most body shops repair with glue now days, its quicker and most of the time the same way the factory installed the skin to begin with.
If the door skin is replaced correctly you shouldnt lose any structural strength
Old Aug 1, 2005 | 09:00 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
a lot (most?) of new cars come new with door skins that are attached with adhesive.
My father just put a GM replacement door skin on the back door of a new Impala, and it uses adhesive to attach the skin to the door frame. The only place it's welded are two tack welds underneath the door post trim.
Old Aug 1, 2005 | 02:14 PM
89rsragtop's Avatar
Car: blue
Where? I couldn't find anybody that makes them.
Old Aug 1, 2005 | 04:57 PM
KEVIN G.'s Avatar
Car: 1984 TRANS AM AERO (PAINT SO DEEP
Engine: 305 CARBED
Transmission: 700 R-4/Vette Servo mod
LINK
Old Aug 1, 2005 | 10:10 PM
89rsragtop's Avatar
Car: blue
Yeah I called them when I was looking. Out of stock, notice they just had left side listed. They have run out and there are no more.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
