TA 85-90 hood on a 91-92 firebird
Old Aug 14, 2005 | 09:16 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I'm new to the 3rd gen firebird, I was a 2nd gen. I have done some reading on all different websites and I'm getting conflicting info. Can a 85-90 TA hood fit on a 91-92 Firebird? I have read and heard that it will not work with the headlights on the 91-92. Please help a newbie. Thx.
Old Aug 14, 2005 | 09:40 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Yes it will work.
Old Aug 14, 2005 | 09:46 PM
Dokken10's Avatar
Car: 91 Formula
Has anyone done it or seen it done. I'm talking about a stock car and stock hood. No other modifications. Thx.
Old Aug 14, 2005 | 11:04 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Yes, 100% sure it will work.
Old Aug 15, 2005 | 10:27 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yes. The hoods are the same and fit with both style of headlights.
Old Aug 16, 2005 | 11:29 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
i have 92 trans am ground effects and lights and my hood is off one of the older t/a's so hope this helps it lined up perfect by the way
Old Aug 16, 2005 | 01:07 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Your confusion is the facias are not directly interchangable.
If you swap an older facia on your T/A it WILL work, however there will be gaps at the leading edge headlights. A 91-92 Facia used on an earlier T/A needs the newer headlights because they will catch on the facia when they open.
However all 82-92 Sheetmetal is interchangable, for each brand except for some differences in hole location for the ground effects, etc.
To simply answer your question in a round about way, the 82-92 Firebird used the same hood for all years. The 85-92 Trans Am and GTA used the same hood for all years. The 91-92 Trans Am, and Base Firebird, uses the same fenders, facia, and all connecting parts when the Base firebird is equiped with the Ground effets package.
Therefore YES it will work.
You can even spend the big bucks and get a Formula hood if you would like
Anjd as Vipershark has shown in his pic the wheels are also interchangable with a Camaro.
John
Frozer!!!
Jan 19, 2024 04:55 PM
LilHot
Exterior Parts for Sale
20
Apr 1, 2016 04:45 PM
silverstang84
Exterior Parts Wanted
Sep 21, 2015 08:05 AM
Wife'sCar
Aug 22, 2015 01:46 PM
Randomtask2
Aug 13, 2015 01:57 AM
