Difference btwn 86 and 92 spoiler ???
Old Aug 15, 2005 | 01:24 AM
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
Does anyone know the difference between the spoilers that are on the backs of the 92 RS and the 85-87? Camaros that didnt have the 3rd brake light. Are the angles the same and are the mounting holes in the same spot ????
Old Aug 15, 2005 | 06:14 AM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
The mounting studs do not line up. The angles are also different.
The early spoiler does not cover as much of the decklid.
Old Aug 15, 2005 | 10:18 AM
ES87iroc's Avatar
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
The 82-86 and 91/92 3 piece spoilers are identical. The 87-90 is a different width as the 3rd lamp is in it.
Old Aug 15, 2005 | 01:10 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
I was ticked when the 86 spoiler did not match my 89. I had to remove some of the studs in my spoiler. Where is the brakelight in the 91-92 in the window?
Old Aug 15, 2005 | 02:50 PM
ES87iroc's Avatar
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Yeppirs.
Old Aug 15, 2005 | 05:09 PM
911rsq's Avatar
Transmission: yes
Are you sure ? You are referring to the early (85-87?) spoiler with no 3rd brake light on it to the 91-92 with no 3rd brake light in it correct.....
Old Aug 15, 2005 | 05:11 PM
911rsq's Avatar
Transmission: yes
The reason these 2 styles did not match up is because the '89's had 3rd brake lights in them. The 86 should not have had one in it. The 91-92 Camaro's have a high mounted 3rd brake light right in the middle top of the rear window.....right in your line of sight out of the rear view mirror
Old Aug 15, 2005 | 05:12 PM
911rsq's Avatar
Transmission: yes
That's what I was looking for.....thanks
Old Aug 15, 2005 | 08:59 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Yeah I was ditching the light.
Old Aug 15, 2005 | 09:09 PM
nick418's Avatar
Engine: L98, Hemi 6.2
BRO I FEEL YA! and i also have the hi rise spoiler! (makes things even worst)
Old Aug 15, 2005 | 09:25 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
It's not like the 3rd brake light is huge or anything. I can see perfectly fine...
Old Aug 16, 2005 | 02:14 AM
911rsq's Avatar
Transmission: yes
Check out nick418's pic above. That's what mine looks like too out of the rear view. It pretty much covers up the entire lane behind you when u look in the rear view....
Old Aug 16, 2005 | 08:07 AM
91Zman's Avatar
Car: 1991 Z28
Last time I checked I have the same view from the mirror as he does in that pic.
Old Aug 16, 2005 | 03:35 PM
911rsq's Avatar
Transmission: yes
Me too, it just gets in the way..... Bothers some, doesn't others...
Old Aug 16, 2005 | 04:46 PM
91Zman's Avatar
Car: 1991 Z28
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TheExaminer
Sep 28, 2015 02:28 PM
BAMiller
Sep 14, 2015 06:38 PM
Numbah-1
Sep 12, 2015 08:57 PM
greenyone
Sep 2, 2015 03:39 PM
