I need motivation to trust myself installing new gauges.
Old Aug 31, 2005 | 05:54 PM
ZZ4 86 Z28's Avatar
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
I bought a new gauge cluster and it came in the mail today. It is the 145 mph one, and suddenly I don't trust mylsef installing it. Also, I supposedly need a new oil pressure and water temperature sending units and I dont know how much they are or what they look like. If anyone can help me out, or tell me about how they did theirs easily or something thatd be great. I also wanted to swap the odometers, so any stories about doing that successfully would be helpful too. Thanks a lot guys.
Old Aug 31, 2005 | 07:48 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
Just take a deep breath and put it in. I've never done it myself, but it can't be that hard. Or could it...
And is switching odometers legal?
Old Aug 31, 2005 | 08:19 PM
ZZ4 86 Z28's Avatar
Well I want the 145 speedo, but i want the mileage to read correctly for the car. i need to get the new sending units first anyways...if this is true that i need them.
Old Aug 31, 2005 | 08:57 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
mileage is exempt on the title because the car is over 10 years old. (at least in NY)
As far as installing the cluster, its straight forward. a few torx on the trim bezel, and a few nuts holding the cluster to the dash.
Old Aug 31, 2005 | 09:13 PM
ZZ4 86 Z28's Avatar
Yea, but I kinda wanted the odometer to read right for myself...not really for legal reasons. I guess I could just write down the mileage and do the math. and did you do it? and if you did, did you need to change those sending units?
Old Aug 31, 2005 | 10:00 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
As for the installing part, just take your time and dont force anything
As for getting the mileage the manufactures website may have an FAQ for that or just email them. If all else fails write the original mileage on the back of the new speedo.
As for sending units they are very small simple units, threaded nipple on one end and wire connection on the other. Should be under $20 ea.
Edit: heres a generic autometer sending unit pic so you know what to look for.
Old Aug 31, 2005 | 10:16 PM
NastyL98_T/A's Avatar
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
fwiw, I didn't have to change any senders. I went from a '90 dash stock with the 120 speedo to an '87 140 speedo. I think the discrepency lies in wether the dash has an oil pressure gauge or dummy light, same for the water temp.
Old Aug 31, 2005 | 10:31 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
^^^ exactly, but your best bet is to just change them to guarantee 100% functionality. They are fairly cheap and are probably going to crap out soon anyways
Old Sep 1, 2005 | 09:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I haven't tried it on a firebird speedo, but on a camaro speedo, it's a piece of cake to open it up and swap the odometer with your original one so that you can maintain your milage. If you tinker with the spare one a little bit, you'll also figure out how to roll it, which comes in useful not only for dirtbags who try to defraud buyers, but for those of us who want new gauges to display an accurate milage.
Old Sep 1, 2005 | 10:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There may be some info in the following link that will be helpful:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Old Sep 1, 2005 | 06:22 PM
ZZ4 86 Z28's Avatar
Well heres the good news. The speedo works. Heres the bad news. The temp stays spiked way above the highest temp on it, the oil pressure gauge also stays spiked, the voltage one reads 2-3 higher than my old one did, and the gas gauges is all screwy and bouncy, and the trip odometer is broken, and the tach reads 500 rpm too high at idle, and i think even more difference at around 2500rpm (havent gone farther yet). So basically i got this whole cluster mainly for the speedo, but its the only thing that works right (beside the regular odometer. ugh!
Old Sep 1, 2005 | 08:08 PM
JamesC's Avatar
Back when I was selling clusters regularly, I always recommended swapping the speedo head into the buyer's cluster. In that way, the buyer was assured that all would function correctly (providing all function correctly before the swap).
JamesC
Old Sep 1, 2005 | 08:24 PM
ZZ4 86 Z28's Avatar
I mean the gauges dont really matter that much to me. I could care less if my tach says 2500 when im actually at like 2000. and the gas gauge doesn't really matter that much to me, i think its straightening out. How could not reading the other ones be a problem. I mean I have taken long trips with absolutely no temperature or oil pressure problems. and i could live with no trip odometer. it just kind of gets me mad that the guy said everything worked. anyway, ill get back on what the seller tells me to do about this little problem. I might just wind up putting the speedo in my old cluster even though it didn't really work perfectly, but definantly much better.
Old Sep 1, 2005 | 09:13 PM
Stevo's Avatar
Car: Pair of 92 Z28s
you can live without a gas guage and trip meter??
how ya gonna know how many miles uve driven? gonna estimate stuff?
Its just plain helpful to have oil pressure / water temp also handy...
coolant leak on the highway u dont know about...could be too late
lots of stuff...think about that one for a minute.
Id spend the extra time and figure out how to hook everything up correctly cause chances are you are gonna actually want all those things youve mentioned...
Old Sep 1, 2005 | 09:17 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
thats what you get for swapping out clusters for a stupid 145mph speedo
(of which, maybe if your lucky, you might hit someday)
sorry i find the swap annoying as 10k tach's in our cars
Old Sep 1, 2005 | 09:22 PM
ZZ4 86 Z28's Avatar
i think i might just use the old cluster, and change the speedo to the new one, and then just sell the new cluster with the old 85.
also, i have hit 85 before and i dont want to break anything. I had to get over a couple lanes to maintain my speed and not get b*tched at by everyone. If I had a 115 I wouldnt care either, plus the 145 looks cool too.
Old Sep 1, 2005 | 09:27 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Winna Winna chicken Dinna!!
I second that. Pull it back apart, and just replace the speedo. Everything will work fine then.
JamesC, nice write-up on the speedo fix. FWIW, I did the same fix on my 145 speedo, but used thick dental floss instead of wire. Has worked fine for over 10 years now.
Old Sep 1, 2005 | 09:39 PM
ZZ4 86 Z28's Avatar
yea, ill take it back out some time this weekend and switch the speedos, thanks for the help guys.
Old Sep 2, 2005 | 05:38 AM
JamesC's Avatar
It's conceivable, I suppose, that the cluster isn't properly seated, and as a consequence contacts aren't mated up correctly. Did you tighten down the 10mm speed nuts? By the way, did you need the senders before the swap? If not, you don't need them now. The swap is just that, one cluster for another (providing idiot lights aren't involved).
JamesC
Old Sep 2, 2005 | 09:41 AM
Jim85IROC's Avatar
if the gauge ground isn't clean and making good contact, the instruments will behave very strangly.
Old Sep 2, 2005 | 01:06 PM
ZZ4 86 Z28's Avatar
thats insteresting. but i think i will just use the old gauges, the "glass" is much cleaner and i know the gauges work. and if i did any of the things you mentioned, I would have to remove and put back the gauges anyways, so might as well. thanks.
Old Sep 3, 2005 | 04:04 PM
Derek The Great's Avatar
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
THe temp and oil pressure gauges stay spiked bc of the old sending units, see those controlled a dummy light, and ground out the connection full time so the light stays off, but since there is now a guage in place of a light, the needle will go as far as it can, just replace the oil and temp sending units with the CORRECT replacement (ie specifi the cars engine when you go the Gm dealer) And as for the tach, are you sure the cluster came out of a camaro with the same engine as you? if not this could cause problems like that.
Old Sep 3, 2005 | 09:35 PM
ZZ4 86 Z28's Avatar
thanks for the advice, but i went ahead and swapped the speedo head into my old cluster, and now every gauge works. Now i just gotta get an explanation from the guy who sold me the gauges.
hectre13
Dec 11, 2023 08:14 AM
AussiePr0nCar
Mar 6, 2020 04:04 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
hectre13
Aug 26, 2015 08:17 AM
litemupp
Southern California Area
Aug 23, 2015 10:09 PM
