4th Gen Washer fluid tank in 3rd gen
Old Sep 17, 2005 | 11:54 PM
  #51
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Another little mod, cut/bend the brace that bolts to the fender/frame.The bottle is in the way.
Old Sep 18, 2005 | 12:00 AM
  #52
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Last one.Here is a diagram if any one wants to see where its all monted to,etc.
Old Sep 18, 2005 | 02:51 AM
  #53
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
interesting. That does seem like a good idea for someone that may go back to stock one day. I like it good job!
Old Sep 18, 2005 | 10:49 PM
  #54
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Originally posted by iansane
I'd really like to see pictures of the light output against a building or something at night.
Here's a pic for you(little blurry though).Have a pic of hi-beams too.
Old Sep 19, 2005 | 01:21 AM
  #55
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
will that 4th gen bottle fit on the driver side? my battery is over there.
Old Sep 19, 2005 | 06:35 PM
  #56
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont see why not ,as far a space goes there's room.The install would be like a mirror image from the pass side(my guess).On my car the C.C. vacum reserve is there.So it would have to be moved.Whereas the batt tray had nothing mounted under it.I say its worth a shot to try.
Old Sep 20, 2005 | 01:12 AM
  #57
Xophertony's Avatar
Axle/Gears: n/a
oh yeah, the power orb! i forgot..... damn. that thing can go anywhere. what i am most worried about is the hard line built into the tray. it will be exiting toward the fender, might have to get some use out of that pipe bender my dad has in the garage.
Old Sep 20, 2005 | 07:06 PM
  #58
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
That aluminum line will come off.I pulled mine out to flush the bottle prior to installing it.
Old Sep 20, 2005 | 11:26 PM
  #59
IROC_5796's Avatar
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
just an idea for the tpi guys.
if that rad overflow would fit on the driver side it could be used as the washer fluid tank.
but its just an idea
Old Sep 22, 2005 | 03:58 AM
  #60
Xophertony's Avatar
Axle/Gears: n/a
oh... hey yeah.
as long as its an 90? or befor cause in 90? the washer reservoirs started using pumps on them instead of pumps on the windshield wiper motor.
Old Sep 22, 2005 | 08:44 AM
  #61
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i dont know about firebirds but my 88 Iroc has an electric washer pump. But my 87 does not. If thats any help
Old Sep 22, 2005 | 02:43 PM
  #62
IROC_5796's Avatar
well on my maro, when i bought it the pump on the side of the tank died and the previous owner installed an in line pump, which worked well. maybe its a solution to the pump being installed on the tank.
Old Sep 22, 2005 | 05:10 PM
  #63
Coult_91's Avatar
Car: 91firebird, 2000 camaro
Engine: 305 tbi,K&N, edelbrock intake & 3.8
Old Sep 22, 2005 | 06:52 PM
  #64
IROC_5796's Avatar
Originally posted by Coult_91
well now i know this mod..........how much hp does it add.....i bet you get you windows real clean really fast..........you better be drop eight turbos or somethin go in the old one place!
are you f**k'n retarded, you must be.. you cant even make a proper sentence.
if you dont have anything to add then shut your face.
go buy a honda or somthing, maybe then you can join an import board and annoy them.
Old Sep 22, 2005 | 09:53 PM
  #65
Coult_91's Avatar
Sorry just kiddin.... good idea.....but no real point...but good job anyway..sorry the ***** burn comment just made me feel bad didnt mean to put you down!
Old Sep 23, 2005 | 08:18 AM
  #66
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
I tried to install a 4th gen washer tank a while back and it would not fit on my 90 camaro. The reason it won't fit is the plastic shields that duct the air from behind the driving lights and the large plastic shield that routes the air from below the car to the radiator also was in the way. If you wanted to remove these parts then it would fit fine.
Old Sep 23, 2005 | 09:32 AM
  #67
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
The only real point would be to clean p the engine bay and use wasted space in the engine compartment that is not really seen.. makes the engine compartment look cleaner.. not to mentin giving a little more space to work on things..
Old Sep 23, 2005 | 01:48 PM
  #68
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
yeah i don't think it fits the TPI cars from what i can tell unless you do some kind of CAI instead of using the stock airbox. It's a good idea especially since I'm going Turbo and the engine bay will already be full. So thanks for the inspiration!.
Old Sep 23, 2005 | 09:02 PM
  #69
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
If you're going turbo, that's going to sit exactly where the easiest place to route intercooler piping...
Old Sep 24, 2005 | 02:35 AM
  #70
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
i was actually considering a setup similiar to Willie and i believe his sn is 89JYturbo with the intercoolers on the bottom of the car instead of the front. I just have to wait until i finish my engine before I start thinking about stuff like that.
Old Sep 24, 2005 | 03:45 AM
  #71
Xophertony's Avatar
Axle/Gears: n/a
i just ordered a coolent tank off of ebay and my washer tank should be here anyday now. i have TPI. but custom intake. i will of course take lots of pics so you all will see how it turns out. i will do the installs on them probably monday but maybe wednesday.
87CIZ ---
your car does have an electric washer pump. it is inside the unit on your firewall that moves the windshield wipers. it draws from that hose and then sprays it out. di you think gravity did that?
my 86 was the same way, but that pump went out so i replaced it with the 92 bottle. (having a pump at the water source provides more water pressure)
Old Sep 27, 2005 | 06:24 PM
  #72
Xophertony's Avatar
Axle/Gears: n/a
well.....
my 86 has a completly different support system for the bumper, the whole thing interfears with the bottle, no amount of bending will make it fit. normally i would give up and just use the working system i have now... but since i am going to the junkyard anyway i am going to look at the stuff there and see if i can kitbash anything together. still doing the coolent thing though!
Old Sep 27, 2005 | 07:00 PM
  #73
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
actually i thought it was vacuum operated..... hmmm
Old Sep 28, 2005 | 03:02 AM
  #74
Xophertony's Avatar
Axle/Gears: n/a
does it hum when you use it? it my be different for 87s
here is a photo of the bracket in my 86. while trying to fit it on there i made a braket out of cardboard and removed the un-ngled straight up and down part and it fit, but then it would loose too much strengh, so i am not going to do that...
Old Sep 28, 2005 | 04:18 AM
  #75
911rsq's Avatar
Car: '91 Z28 & '90 RS Vert & '89 RS
Engine: 5.7L & none & 2.8L (soon to be LSX)
Transmission: yes
Axle/Gears: One's with teeeeefs
You could modify the newer style to fit. It doesnt look like it would be too bad. The bottom and the latch area appear to be very similar. It looks like the only real diff would be on how it mounts to the front bumper......... Then you could prob mock it up
Old Sep 28, 2005 | 08:25 PM
  #76
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Maybe you could use the camaro braces OR a combination of both.
Old Sep 28, 2005 | 10:32 PM
  #77
911rsq's Avatar
Transmission: yes
Old Sep 29, 2005 | 04:12 AM
  #78
Xophertony's Avatar
Axle/Gears: n/a
other then the one on my car i have never even seen the kinds other thirdgens use, so this junkyard trip will be a "fact finding" as well as part finding trip.
in addition to this stuff i
am also seeking:
turn signal swith from inside steering column
wiper delay switch from inside column
screw for the rearview mirror
aluminum driveshaft (yeah right)
retainer clips for the i pillar plastic
rally style guage face
and of course anything else worth taking
i will snap photos of all the different kinds of brackets i see. the yards i go to do not allow cameras, but my phone has a dam nice camera, and they will never know
Old Sep 30, 2005 | 03:30 AM
  #79
Xophertony's Avatar
Axle/Gears: n/a
well i got it. no modifiacation to the tank is required if you put it on a firebird. there is however alot of modification required to the firebird. here is the finished job.
also, a camaro bracket wont work, the maro hood spring is on the oposite side as a firebird hood spring.
<A HREF="http://home.comcast.net/~xophertony/IMAGES/4thgenwasherbottle.jpg">
<IMG SRC="http://home.comcast.net/~xophertony/IMAGES/4thgenwasherbottle.jpg" HEIGHT=334 WIDTH=450 ALIGN=LEFT HSPACE=10></A>
there were alot of modifications involved. for a full write up visit my website.
Old Sep 30, 2005 | 07:40 PM
  #80
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I like it.Wish i was able to refill my tank as easy as you will be able to.Well done.How is the bottom held in place?
Old Oct 1, 2005 | 01:38 AM
  #81
Xophertony's Avatar
Axle/Gears: n/a
zip ties. full write up with lots of photos on my webpage. here is one of the bottle in before the plate was removed. before anyone jumps in about the wealding on the bracket I KNOW. IT'S THE WORST EVER! i realised later that the round stock i "wealded" to the bracket was aluminum steel alloy. i will be replacing the bracket.
<A HREF="http://home.comcast.net/~xophertony/IMAGES/bottleinplace.jpg">
<IMG SRC="http://home.comcast.net/~xophertony/IMAGES/bottleinplace.jpg" HEIGHT=334 WIDTH=450 ALIGN=RIGHT HSPACE=10></A>
yeah there it is, click it for a full size version
Old Oct 1, 2005 | 01:44 AM
  #82
Xophertony's Avatar
Axle/Gears: n/a
841le- you never have posted a pic of what yours looks like with the cover back in place.
Old Oct 1, 2005 | 12:06 PM
  #83
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Sorry thought i did.It looks the same as stock with the cover on though.
Old Oct 1, 2005 | 02:34 PM
  #84
Xophertony's Avatar
Axle/Gears: n/a
totaly stealth. but now you have to remove that cover to fill that bottle that sucks. but it sure made the engine bay look nice
Old Oct 2, 2005 | 01:45 AM
  #85
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats the only drawback.At least the tank holds more water than the original one.
Old Oct 2, 2005 | 03:43 AM
  #86
Xophertony's Avatar
Axle/Gears: n/a
yeah, you may have to remove the cover to fill the bottle (wich apears to be way easyer on camaros by the way, on the fb it is part of the bumper support structure and with the bottle in is almost imposable to remove) but you will only havto do it a few times a year.
you know whats goofy though? the raised section on the drivers side of the bottle that mirrors the side with the lid. it will never get water it it yet it is part of the reservoir, had they made it just an extended mounting point (a smaller section reaching the same height, yet not hollow) they could have saved a bit of money.
well i am still waiting on my coolant bottle. once i finish mine this thread will have a full spectrum of info. we will have covered instilations in both camaros and firebirds. and the coolant reservoir on both drivers and passanger side. makes me feel kinda speacial.
Old Oct 2, 2005 | 09:06 PM
  #87
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah just plastic rivets.Good thing Im in So.cal,It hardley ever rains nor does my windshield stay dirty long enough to use my washer fluid,before i wash the car.
..I noticed there is a pin hole on that part of the tank.I believe its raised up this way to push any trapped air out that way.So it doesnt have to bubble its way back thru the fill cap?
.Hopefully your install on this will go as easy as mine.The other day i was looking at a 4th gen in a mag & noticed they have the charcoal canister in that space by the filler neck.Now that the driver side fender well is wide open.I really noticed my charcoal canister & thought this may be another project to look into.Oh well here i go again......
Old Oct 3, 2005 | 03:44 PM
  #88
Xophertony's Avatar
Axle/Gears: n/a
my charchol canister stoped working, so i removed it long ago...
Old Oct 3, 2005 | 06:57 PM
  #89
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I wish i could do that in Ca.I hope i wont get a "fail" on the smog test with just the visual if/when i relocate this canister!!!
Old Oct 5, 2005 | 09:36 PM
  #90
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Here's mine:
Old Oct 5, 2005 | 09:38 PM
  #91
shr00m's Avatar
Filler Cap:
Old Oct 5, 2005 | 09:41 PM
  #92
shr00m's Avatar
Here's the coolant tank.. I still need to clean up and paint the brackets. Now if I can just get the engine bay painted and get the LS1 that goes with these, I'll be set.
Old Oct 5, 2005 | 09:50 PM
  #93
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Real nice.How much higher will the batt be.Does it clear everything it did before?That was my one concern for mounting mine under the stock tray..Wish i was getting an LS1
Old Oct 5, 2005 | 10:08 PM
  #94
shr00m's Avatar
It's about 2" higher. The battery is a little bit lower than the radiator support, everything clears fine. Of course I had to cut a funky shape in the tray, cut half the fender brace off, and drill and tap two holes to mount it.
Thanks for the work on this.
Kevin D.
Old Oct 10, 2005 | 07:51 PM
  #95
Xophertony's Avatar
Axle/Gears: n/a
wow! your bottle looks a lot better then mine! where did you attach it. does it sid alot lower or did you modify the bottle to be less intrusive to the hood latch plate. you can see how i had to bucher mine
Old Oct 10, 2005 | 09:14 PM
  #96
shr00m's Avatar
You can see the two small rectangular brackets I bolted to the radiator support sides. The holes in the brackets allow the stock push-pins to be used. The V portion of the middle bracket holds the bottom in place tight. It does sit lower and a little to the left (to line up with a low part in the top plate and let the pump clear the middle bracket)
Kevin D.
Old Oct 11, 2005 | 03:47 PM
  #97
Xophertony's Avatar
Axle/Gears: n/a
i might have to get another top plate out of a junkyard and do mine over again, i allready have to go and get another triangle bracket.
Old Oct 13, 2005 | 11:45 PM
  #98
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
how much did you guys pay for the 2 bottles? I've been looking on message boards and everyone is wanting like $70! I'm sure i can get them cheaper at a local yard but geez people say they cost alot to ship.
Old Oct 14, 2005 | 12:04 AM
  #99
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I paid around $6ea.Although it was a 50% off weekend at the J.K.
Old Oct 14, 2005 | 02:19 AM
  #100
Xophertony's Avatar
Axle/Gears: n/a
about 40 total including shipping and hoses... ebay
