Seat back return spring! Please help ...GTA SEATS
Old Sep 13, 2005 | 11:17 AM
formula1vhs's Avatar
Car: 1989 TRANS AM GTA
Engine: 350 CU 5,7L
Transmission: TH400R
Hi guys I got a problem!
I'm in italy and i was removing my ULTIMA style gta lumbar seats.
I'm doing this to replae the old leather covers with the HAWKS's thirdgen ones.
Well I removed te pass seat and i was dividing te back from the seat ad te damned circular (loaded) spring has falled down,i mean the spring that made te seat back come upright when u down it.... hope that i can explain my problem..
Also changing the seat covers it's a PITA!
Maybe tomorrow i will post a pic of the situation....
Thanks in advance...
Old Sep 14, 2005 | 10:28 AM
Engine: 350 CU 5,7L
ok , here's the pic of what i mean:
this one is the damned hellish SPRING
Attached Thumbnails Seat back return spring! Please help ...GTA SEATS-spring.jpg
Old Sep 14, 2005 | 10:29 AM
Engine: 350 CU 5,7L
this is the assembly:
Attached Thumbnails Seat back return spring! Please help ...GTA SEATS-mollone.jpg
Old Sep 14, 2005 | 10:31 AM
Engine: 350 CU 5,7L
and here's the last , this seems to be the right position ,but after trying i was not able to load the spring , please help!
Attached Thumbnails Seat back return spring! Please help ...GTA SEATS-assembly.jpg
Old Sep 14, 2005 | 10:32 AM
Engine: 350 CU 5,7L
This is the complete assembly...
Note that i putted back the spring without load it , it seems to go this way ( after trying) but i'm not sure... who can help?
Old Sep 15, 2005 | 09:25 PM
TorchRay's Avatar
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
formulavh1:: I think i understand what your talking about. Are you saying that the lever that you pull to make the back of the seat go down and then spring back up is lose and doesnt do anything? if so..i had the same problem. Ill try and explain it the best i can. Ill see if i can get a pic for you tomorrow but i tried to use yours the best i can. There is a spring that goes in like the middle of the assembly that hooks around the metal frame work..and then hooks around the seat lever, that allows the lever to spring back and fourth and also allows the seat to spring back and fourth. Heres the pic. Hope this helps out somewhat. let me know if it does.
Old Sep 17, 2005 | 12:58 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
That spring is more for the handle/lever.It is between the frames of the recline assembly.The coiled spring he is refering to makes the reclined seat go back up.It has broken loose & getting it back on can be hell if not a bit dangerous if it recoils & breaks loose while trying to re-install it.It looks like you will have to turn it clockwise to pre-load it.It looks to be in the wrong spot in your pic.Be careful.
Old Sep 17, 2005 | 07:46 PM
TorchRay's Avatar
Car: 89 WS6 Formula
thanks 841le for corecting me and putting the recoil spring diagram in the picture. Hope this helps him out.
Old Sep 30, 2005 | 03:29 PM
Engine: 350 CU 5,7L
this helped me alot!
Thank you.
It was a pita.
I wrapped a big metal wire (eletric)to the spring, i've bolted the assembly to the table and with a buddy we have pulled as damned and with the help of a screwdriver whe doed it!
Thank you
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Mister_Johnny99
Interior Parts Wanted
Aug 14, 2015 12:59 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
scottmoyer
Aug 9, 2015 10:18 PM
