how to get seats out?
Old Sep 13, 2005 | 04:43 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
all the bolts that hold the seat brackets to the floor are rounded off and i cant get them out, is there anyway to take the seat off the hinges or what? everything is rusted and stuck. WTF can i do?
Old Sep 13, 2005 | 05:44 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Vice grips.
Old Sep 13, 2005 | 05:56 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Try spraying/applying some PB Blaster penetrating fluid to the rusted/rounded off nuts a night before you attempt to take them off w/ the above said Vice Grips... good luck.
Old Sep 13, 2005 | 05:58 PM
82knightrider's Avatar
Transmission: TH200C....700R4
Yeah,vice grips and spray some liquid wrench or PB blaster on there and you should be good to go
Old Sep 13, 2005 | 06:32 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
tried all of the above, still no go. if i still cant get them off, maybe ill just grind the bolts off and weld the brackets to the new floorpan.*sigh* i pulled up a corner of a carpet looking for the floor, needless to say i didnt find it, HOLY RUST!! wait til i post up pix of the floor. its a good thing this car was free and i will be doing up the car in school.
Old Sep 13, 2005 | 07:10 PM
Car: 86 T/A
Engine: HSR 355
Dremel the nut off so the stud is in tact?
Old Sep 13, 2005 | 07:14 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
i was thinking about that... but if i mess up the stud then im screwed right?
Old Sep 13, 2005 | 08:56 PM
get some leverage on those vice grips.And a new pair if yours are worn out
Old Sep 14, 2005 | 03:36 AM
sr.bond's Avatar
Car: 1982-z-28.1987 sc
Engine: 350 on z-28,305 on sc
Transmission: bw t-10 on z-28,700r4 on sc
use a torch to heat the nuts,then spray some wd 40 and go berserk with the vise grips,just be VERY,VERY careful not to torch the whole car
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
