door cupholders?
Old Sep 25, 2005 | 05:41 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
Transmission: 5 speed
door cupholders?
Hi, I am wondering what is the best way to install these cup holders, do i just screw them in with machines screws? i read somewhere on the later f-body 88 and up door panels, they already have the holes build in the door's sheet metal, but mine is a 84. The screws that come with the cupholders are not machine screws and are very long, I think they are on some of the later model firebirds. thanks
Attached Thumbnails door cupholders?-84-z28-305-h.o.
Old Sep 25, 2005 | 07:33 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Re: door cupholders?
Did those door pockets come standard on the Camaro? I thought they were just a Firebird thing (naive, I know). I just replaced one of these on my car and used the stock hardware which is why I ask about this on the Camaro.
Howdy and welcome to TGO to you from just south of you.
Old Sep 25, 2005 | 07:38 PM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
they only came with the firebirds, but i always want it some on my camaro, and they did not make them back in 84, so i purchase them for my car, by the way, does your door already have the holes build in? sinece you just replace yours, any help would be appreciated. thanks.
Old Sep 25, 2005 | 09:58 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Remove the door panel. Hold the cupholder/map pocket up to the door. If you find that there are three square holes that match up with the holes in the cupholder, then go to the HELP section of the auto parts store and get some white plastic license plate inserts. They come 4 to a package so you'll need two packages. If no square holes, then you could just drill the inner door and use sheet metal screws.
Lon
Old Sep 26, 2005 | 12:25 AM
redcamz's Avatar
Car: 84 camaro z28
Engine: 305 H.O.
thanks Lon for the info about the cup holders, by the way, the alston SFC i purchase from you was excellent, i do feel a big difference in the car. thanks again
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
