removing layers on the rim?
Old Sep 29, 2005 | 01:12 PM
eagle_eyes's Avatar
Car: 1988 Pontiac firebird
Engine: '93 LT1
Transmission: Built 700R4
Axle/Gears: 3.70 9 bolt
i have a potiac rim that has the outer layer flacking away. i can sand it down to the next layer, but i was wondering if that would cause the rim to rust? if i do this, would i need some sort of protective coating?
Old Sep 29, 2005 | 01:17 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
They're aluminum, not steel, so they won't rust.
Better idea is to get some aircraft stripper (Autozone, O'Reilly's, Pep Boys, etc. has it) and strip the old clear coat off. Then you can lightly sand it with 600 or 800 grit and use a buffing wheel on an electric drill to really polish them up nicely.
Optionally you could put some more clear coat after you do all that, or just wax them up real good.
Just don't get the stripper on anything you want the color to stay on (inside the ribs, lettering, etc.)
Old Sep 29, 2005 | 04:17 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I did that to mine, but rain drops leave little water spots as they oxidize the aluminum. It's not a big deal and a little polish removes it perfectly, but I'd recommend a clear coat.
Also, I see the rim has no tire mounted to it, but in case you strip other rims with tires, tape off the rubber or the stripper may deteriorate the tire.
Old Sep 29, 2005 | 05:42 PM
vernw's Avatar
So that's why I get the little water spots!
Now I wonder how well I can rattle can clear coat.....
Old Sep 30, 2005 | 03:12 PM
eagle_eyes's Avatar
Engine: '93 LT1
thanks for the replies. i thought that they wouldn't rust, but i wanted to make sure...'cause i've seen soda cans rust before. thanks.
my86bird
Oct 23, 2015 12:20 PM
fasteddi
Sep 10, 2015 09:32 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
RyanJB
Sep 2, 2015 01:27 PM
