interior help.
Old Sep 30, 2005 | 05:31 PM
90tbi305's Avatar
Car: 1990 350 tbi l98,
Engine: 5.7 tbi
Transmission: t5
interior help.
I want to take of the gauge cluster, and having problem with the headlamp toggle switch, How do you remove this?
Old Sep 30, 2005 | 05:42 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Any one please need help quick.
Old Sep 30, 2005 | 05:52 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Any one?????
Old Oct 1, 2005 | 01:58 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
you talking about the **** for the lights? Or the dimmer switch on the column? if its the dimmer switch on the column which I'm guessing is what your wanting just yank on it straight out. Be careful if you have cruise control not to yank to far.
Old Oct 1, 2005 | 08:48 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
Had this problem myself one time, it's rather simple. First, to get the button off, feel around for a little metal tab behind it. Push it up with a small screwdriver, button is off. Then, to get the rod out , if you look, it's a triangle rod that goes to a box. On the bottom of the box is a small pin. Push the pin up (rahter hard) and the rod should pop out.
Old Oct 1, 2005 | 12:34 PM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
Do a this has been covered many times. Don't just yank on the headlight button if you have a 91-92. If you do the **** will come off but you won't be able to reinstall the button and will have to replace the headlight switch. Instead reach underneath and push the release button and pull the entire rod out. The yank method did work on my '86 but not my '92.
Old Oct 1, 2005 | 01:03 PM
90tbi305's Avatar
Engine: 5.7 tbi
Transmission: t5
Thanks guys. -eric
Old Oct 1, 2005 | 02:14 PM
Axle/Gears: Posi
Bubbajones_ya
Jul 6, 2024 08:32 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Numbah-1
Sep 12, 2015 08:57 PM
Keiffer76
Sep 9, 2015 08:52 PM
scottmoyer
Sep 7, 2015 07:06 PM
