How to make your braided hoses look nice at the end?
Old Oct 7, 2005 | 07:37 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I'm replacing alot of my old worn out hoses with stainless steel braided ones since it looks better. The problem is the end of all my hoses just fray and look awful, is there any way to clean up the ends and keep them from fraying? Thanks!
Old Oct 7, 2005 | 07:48 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
are you using braided -AN line or the hose covers? If it's -AN, wrap some electrical tape tight around where you want to cut and use a bandsaw to slice through the hose. This will keep it from fraying while you put the ends on.
Old Oct 7, 2005 | 07:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I take it you're not using AN fittings? Several vendors make aluminum hose clamp covers that look like fittings.
Old Oct 7, 2005 | 07:59 PM
Car: 86 T/A
Engine: HSR 355
Right, these aren't AN sizes.
Thanks for the heads up on the fake clamps.
Old Oct 7, 2005 | 09:35 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Car craft just gave a tip for this in the latest issue.Take a large chisel and sharpen it as sharp as possible. Then take your new shank and a decent hammer (5lb sledge) and cut the hose to length. They say it works very well.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
novaderrik
Aug 10, 2015 12:44 PM
