little light found under 91 pass side dash
Old Oct 27, 2005 | 01:37 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
hey guys I found a light with wiring still hooked up(I think its a light car is in shambles with no battery so I coudnt exactly check) anyways it looks exactly the same as the kind of light which is right under the center vents above the hvac. except bigger and is a bluish color? I saw it just kinda laying around by where the pass side speaker is..... is there a place for this....?
cheers
blake
Old Oct 27, 2005 | 09:08 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Above the stereo/ashtray area. Right under the trim piece that holds the rear hatch release, fog lights and defog switch in a TA. Camaro should have a simular setup.
Old Oct 28, 2005 | 02:58 AM
Willbanks's Avatar
Car: 1991 Z28 Camaro
Should be a trip peice that attaches under the passanger side dash area. The trim peice has a white bubble ( for a 84 camaro anyway ) to place a light inside of it. If it's not attached you are prob missing the trim peice.
Old Oct 28, 2005 | 12:34 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My 88 has a 194 bulb in a holder that twists into the hush panel under the dash there. Just like a side marker light. Maybe someone just liked the blue light?
Old Oct 28, 2005 | 01:27 PM
91Z-TheReaper's Avatar
Car: 88 IROC
Engine: 350 L98
Transmission: T5 - 5 Speed
I just tore apart a 91...
If its what I think it is, its just the normal pass. side interior. There should be a slotted hole in your kick panel and the light should slide in, then turn to lock. The hole should be right behind where your computer mounts.
Old Oct 31, 2005 | 11:24 AM
CDNMARO's Avatar
Car: 87 Camaro SC
Transmission: 5-Speed
Re: little light found under 91 pass side dash
cheers
blake
The thing you describe, is not actually a light, but the daylight sensor for the automatic headlights. There should be a toonie sized plastic cover on the dash next to the passenger speaker. The *light* you describe should go under it. If it's missing, chances are somebody replaced the dash pad with an older one & that's why it's under the speaker.
Plastic Cover
Daylight sensor
Old Oct 31, 2005 | 11:26 AM
Car: 88 IROC
Engine: 350 L98
It definitely is the daylight sensor. My bad. I actually pulled off the dash pad last night, and guess what, there was that little 'blue light'...
bjpotter
Aug 12, 2015 06:06 PM
wruiz
Aug 11, 2015 02:59 PM
Omega
Aug 10, 2015 12:46 PM
antares57
Aug 6, 2015 07:47 AM
3rdgenparts
Aug 5, 2015 11:57 PM
