Wonder Bar?
Car: 89RS,89TBI FB, 91Z28, 89TPI FORMULA
Engine: 357 SBC TPI
Transmission: World Class T-5 (for now)
Axle/Gears: Strange 12-bolt 3.73
Wonder Bar?
I've read about the magical wonder bar that graced some IROCs. I'm wondering, my 89 Formula has a brace or bar of some kind that runs perpendicular to the frame and is bolted to the rear-most of the front frame members...it's right inder the front seats. Do I have a wonder bar?
Before I get flamed, I am not claiming to have a rare or special Firebird, nor will I be looking for a one-off RPO code.
Thanks,
Eric
Thanks,
Eric
got a pic.... i had to read what you said a few times and still a bit confused.... the wonder bar is up front and runs perpendicular with the sway bar infact its bolted in the same place as the sway bar on the front subframes, anyways it sounds like you got SFC? if im reading it right?
Engine: 357 SBC TPI
No, I don't have a pic, but this piece is probably a subframe connector like you say. It's nowhere near the sway bar. Do you think this was an add-on piece or standard equpiment? I know so little about torsional ridgitiy...what benefit would I reap from an SFC?
Thank you for your help BTW........
Eric
Eric
Car: 1992 Camaro RS
Engine: 3.1L
Have a look at https://www.thirdgen.org/techbb2/sho...hreadid=327835 In the first picture the wonderbar is the black bar right next to the red sway bar.
Engine: 357 SBC TPI
M-I-O: that helped a bunch. I don't have the wonder bar.
SFC or Xmission crossmember..it ain''t the WB so thanks everyone for the help.
darwinprice
17
Oct 11, 2015 11:51 PM
