How to make clean holes in console?
Old Nov 20, 2005 | 02:33 PM
Bull's Avatar
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Well, I soon will be taking the plunge and seeing how hard it is to do a manual 4th gen console swap. I will need to figure out how to wire up some switches for my power windows and power mirrors as well, and I know that involves cutting holes in the console. My question is, what is the preferred method to do this type of cutting? In my limited experience, I have found that Dremels and the like create a huge amount of heat which melts the platic you are trying to cut, making precision difficult. I'd appreciate any guidance you can give.
Also, I've done a search, and found some ideas for what kinds of window switches and mirror switches to use, but there seems to be a lot of info to digest. If someone has a fairly simple swap that they did, I'd be very interested in hearing what switches were used, how they were mounted, and how they were wired up.
Many, many thanks in advance. My fiance will be super-excited to finally have her cupholders in the car!
Old Nov 20, 2005 | 02:53 PM
jandl22's Avatar
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
I bet one of those zip tools with a small bit would do a great job.
Old Nov 20, 2005 | 04:38 PM
Bull's Avatar
Engine: LT1; None
Ok, I spent even more time combing through different search results. Both the Contour and Saturn window switches appeal to me, as does the 4th gen mirror switch.
My question now involves what I need to get with the switches. Is a "pigtail" or whatever you call it that plugs into the switch, available new from GM for the 4th gen window switch? Do I need it, or can I use my thirden switch wiring? If I find Contour or Saturn window switches, do I need any of their original wiring as well?
Oh, and with the window switches, the ones I have seen on Ebay for the Saturns seem to come attached to a larger plastic bezel. Do you remove them from this bezel and then fab up a mounting plate to put them in the ashtray of the 4th gen console?
I know I have a lot of questions, but I have done a few searches to get me started.
Lawrence, I do have a Rotozip...
Old Nov 20, 2005 | 07:19 PM
88txiroc's Avatar
Do NOT use a high speed tool to cut plastic. As you stated, it will melt. Use a good quality drill bit in a cordless drill. Start slow and use slight pressure. Let the bit do the cutting, and you will get a nice, clean hole.
If you need to make larger holes/sqaures, use the drill bit for the corners. Then you can use a sharp utility knife and a hack saw blade to finish the hole. Put down some masking tape before you start, and draw the lines on it.
Old Nov 20, 2005 | 08:54 PM
jandl22's Avatar
Engine: 2.5 151 TBI
I can agree with you about using some tape around the holes or squares you are cutting, but a roto zip does a fast, clean job that will not melt any plastic. Maybe I should not have said this to you because you will delete my post
Good luck on the work and please show us some before, during, and after pictures.
Old Nov 20, 2005 | 09:03 PM
Bull's Avatar
Engine: LT1; None
Good idea about the masking tape, I wouldn't have thought to do that on my own.
Lawrence, I'll take some pics, but I won't share them if I end up doing a cruddy job!
Old Nov 20, 2005 | 09:06 PM
jandl22's Avatar
Engine: 2.5 151 TBI
Practice on a similar piece of plastic first, that way you can be sure.
Good luck on your conversion.
Old Nov 21, 2005 | 07:57 AM
88txiroc's Avatar
Why would I do that? If you have used a Roto to make clean holes in plastic, then it is good technical advice. I have always used the tried and true method of slow and steady when dealing with plastic. Granted, I have used power saws to make cuts in large panels of plexi, but for small holes, I would only use a drill/sharp knife.
Old Nov 24, 2005 | 11:31 AM
snapsmagee2000's Avatar
Car: 91 z28 100kmiles
Transmission: 700r4 hoping to be t-5 soon
Axle/Gears: 3.42 posi
use a hot knife to cut it
Old Nov 24, 2005 | 12:49 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i used a dremel and cutting blade with NO melting issues and all of my lines came out as planned.
this is also a pic of what i did with my mirror button and used a dremel to cut that hole as well.
take it slow and dont hurry the blade thru and there wont be any melting.
http://www.pontiactorque.com/quickch...sole_00007.JPG
http://www.pontiactorque.com/quickch...sole_00014.JPG
http://www.pontiactorque.com/quickch...sole_00002.JPG
Jeremys87
Jul 14, 2022 09:08 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Casey Meyers
Mar 2, 2016 10:46 AM
TheJoeY88
Aug 13, 2015 06:51 PM
