t top winter precautions..
Old Nov 25, 2005 | 11:27 AM
91blue_fire's Avatar
Car: 1985 iroc-z
Engine: 305 tpi with hooker super comp exhaust
Transmission: stock 700r4
ive got an 85 iroc and last night was one of the 1st below freezing nights around here. there was ice on my tops and when i went around a corner i heard a crack...it was the ice, not the tops. but with it being so cold is there anything i should look out for\do for my t tops during the winter? i dont want them 2 crack or anything. i read somewhere that the heat from ur heater with it being real cold out could crack them? thats not true is it? doesnt sound it to me..but..u never know. anyways, let me know if u guys can think of somethings all of us winter time 3rd genners should look out for!
Old Nov 25, 2005 | 11:40 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Got glass or lexan tops? I had both, I did nothing to prep either for the winter. Just don't bang em around when its freezing and you'll be fine.
Old Nov 25, 2005 | 12:18 PM
Car: 1985 iroc-z
oh sorry man, i prolly forgot 2 mention my cars an 85, so im guessing thats the glass tops. lexan was later, like 90- newer right? what do u mean by banging em around? like if i decide 2 take em off 2 clean them or something?
Old Nov 25, 2005 | 12:29 PM
Car: 86 T/A
Engine: HSR 355
I mean... they're glass. It won't just break from the cold. Personally I wouldn't remove them during the winter (no reason to anyway) just becuase the rubber is harder at that time. My main problem was the cold always seems to ruin those seals on the outside that overhangs the window glass. No way around it really, comes with age.
Old Nov 25, 2005 | 04:09 PM
White93z34's Avatar
Car: 1987 Camaro IROC-Z
Engine: LB9
since i'm storing my car for the winter i think all i'm gona do is either buy a car cover for it, or get a tube of clear silicone and seal the edges of the t tops so moisture cannot find its way in.
Old Nov 25, 2005 | 05:25 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
my defroster cracked my windshield from blowing right on it in the winter but i dont think you would have that problem with the t-tops
Old Nov 25, 2005 | 05:59 PM
Car: 86 T/A
Engine: HSR 355
If you get a car cover get a good one. My $50 deal from Summit let's moisture through, rubs off my paint, tore already, and doesn't fit at all. Summit blows.
Old Nov 25, 2005 | 06:27 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
lol when winter hits is usually when mine never leak because the water freezes in the cracks. My stripping is getting perfessionally fixed monday tho.
Old Nov 25, 2005 | 07:16 PM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
nobody takes the t-tops off in the winter? =D
Old Nov 26, 2005 | 01:56 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I've been known to take my t-tops off in the winter, as long as it's not raining and the sun is out. Kind of rare here in the Pac Northwest.
Old Nov 26, 2005 | 01:03 PM
Car: 1985 iroc-z
u guys ever had ice on the inside of the car? ive had ice lines around in the inside of the car on the t tops. it looks like its cracked, its cool looking. but...makes me wonder how much moisture is comming in my car......
Old Nov 26, 2005 | 01:40 PM
1982TA's Avatar
Car: 1982 Trans Am
Engine: SBC 400
Transmission: 700-R4
Axle/Gears: 9 Bolt 2.77
Re: t top winter precautions..
Originally posted by 91blue_fire
i i read somewhere that the heat from ur heater with it being real cold out could crack them? thats not true is it?
Does your windshield crack when you have the defrost on?? The only way they will crack is if you dump a bucket of hot water on them...
didn't see the above post about the cracked windshild with defrost on...
Anyway, I cracked my windshild last winter by trying to pound the ice of with my fist. Cracked it in two places
Old Nov 26, 2005 | 08:34 PM
tagta189's Avatar
If you are going to worry about stuff like the t-tops then there are alot more immediate things I would concern myself with first.Like the dashpad.You might want to remove that sucker and get it inside for the real cold part of winter.They are famous for cracking in the really coldest most miserable parts of winter.
Old Nov 27, 2005 | 01:07 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
If you want to protect your car, don't expect $50 to do the trick. I bought my CoverCraft cover from summit for $250. It lets in water, but only so it can let it back out again. I've had the cover for 5 years, it is a custom fit, and on super windy days i have to tie it from eyelid to eyelid under the car. It has not ripped, I can wash it at home in my washing machine, and it's thick and soft, protecting it from acorns, etc. dinging the car.
-Jim
86CamaroDan
Sep 29, 2015 10:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
