gauges :lookhere:
Car: 88 Formula
Engine: 350 TPI / supercharged
Transmission: 5spd manual / dual friction centerforce clutch 373 rear end
gauges :lookhere:
instrument cluster lamps not working remote dimmer is good fuses is good speed,oil,temp,volts,rpm, good but no light in the guages at night am i missing something ,,,,, little history i just changed my whole dash from my transam to my other 88 tpi its all the same and the computer is swaped with correct one . umm.. help please
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Got a voltage meter? It's the only way you'll figure it out, just get a wiring diagram and follow where the power goes.
