Firebird headlight assembly adjustment?
Old Nov 30, 2005 | 11:17 AM
Redbird's Avatar
Car: '87 Firebird
Engine: '89 Corvette L98, unstock
Axle/Gears: 3.23 posi
Is there a procedure for adjusting the headlight assembly to match the body? Or do you just loosen everything and try to line it up?
TIA
Old Nov 30, 2005 | 08:33 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
All of the mounting brackets are slotted, so you can adjust the headlight bucket up/down and side to side. You can also adjust the up and down stops for the headlight bucket as well. Those are done by tuning in or out the plastic hex-head screws.
Lon
Old Dec 2, 2005 | 11:46 AM
89bluirocz's Avatar
Car: 1989 Iroc-Z
Engine: 350 tpi
Transmission: Swapped in T5
well i couldnt ever get mine to line up right so i did the next best thing since im gettin ready to paint it. i got it as close as i could and the we laid on some fiberglass lol now its really smooth and there nothin wrong.
Old Sep 13, 2006 | 09:54 PM
turbotaguy's Avatar
I need to adjust the lower stop on my driver headlight, where the hell are the plastic hex head screws that you guys refer to?
Old Sep 14, 2006 | 06:20 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
Take out the headlight bulb and you will see them. There are two of them, one near the top and one near the bottom.
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
BurlyChev
Aug 22, 2015 01:52 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
