Question about 90-92 camaro gauges
Old Dec 27, 2005 | 02:14 AM
86birdHT's Avatar
Car: 2004 Pontiac GTO
Axle/Gears: IRS 3.46
I did a few searches and nothing came up with the answer i wanted.
I was thinking about switching my current gauge cluster from my 88 iroc to the 145mph from the 90-92 IROC/Z28s but I wasnt sure if it would fit fine or if the connectors would be the same...
I've only really driven one 90+ dash car and liked the way it looked, and think it would be a nice touch to my interior...if it fits.
I also dont even remember if its the same size lol
Thanks, and sorry for the odd questions
Old Dec 27, 2005 | 10:00 AM
cdoyle's Avatar
the 90-92 dash is totally different from the 88.
92
88
The wiring on the connectors changed too, do a search there are a couple that swapped out the dash, and rewired the car so they could have the 90-92 cluster.
I want to do this someday, have the entire dashboard of a 92 sitting in the garage. Just a big project, and just havne't had the time.
Old Dec 27, 2005 | 10:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you have to swap the entire dashboard for it to fit right.. you can retain the top dash piece though...
rewiring most of it to work isnt too hard, hardest part is adding the electric speedo stuff.
overall, its nothing exceptionally hard, just ALOT of little things.
Old Dec 27, 2005 | 11:06 AM
86birdHT's Avatar
I thought the Camaros had electronic speedos in 88? I know the firebirds had them in 86, but did the Camaro transfer over after that?
Anyway, dont really feel like replacing my entire dash for a cool looking gauge cluster, dont really have the time
guess I'll just try to freshen up my current one
Old Dec 27, 2005 | 12:24 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
camaros had mechanical speedos until the new dash setup in 90.. 90-92 had electrical.
from 82 until 89, the VSS was located on the back of the speedo.. the cable turned the speedo, and that turned the speed sensor... the ECM then got that signal.
90+ models had the VSS mounted in the tailshaft of the trans... wires then ran the signal to the gauge cluster, ECM and cruise control.
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
squiggy2
Aug 9, 2015 09:30 PM
