Help with door removal please?
Old Jan 1, 2006 | 10:40 PM
kingair130's Avatar
Car: 1989 IROC-Z/T-tops
Hey guys,
I have a 91 RS and have the trim,wire harness,spring (from the bottom hinge) off of the passenger door. I am at the step where you're supposed to knock the pin up out of the lower hinge, and was just making sure that there's nothing that I'm overlooking, and if anyone had any technique other than what the book says. The book says grab the bottom end with a pliers and hit with a hammer upward, and me and my friend were banging at it for over 2 hours and not making a milimeter. We tried wiggling the door at the same time, spraying lithium lube but to no avail. Any help or advice would be extremely appreciated! Thanks!
Old Jan 2, 2006 | 04:25 AM
restored92's Avatar
you have to take the whole door hinge off then, i forgot what i used to take the three screws out with but be careful because the door will drop and now thar i got the whole hinge off i still havent got the pin out
Old Jan 2, 2006 | 11:24 AM
kingair130's Avatar
Well, the top hinge looks easy, just 3 bolt heads sticking out, but the bottom it looks like maybe the bolts are the other way around. Do I have to take off the bottom interior panel just left of the lower dash panel to acess the head side of the bolts? If so, How does that panel come off because I am only able to see 2 screws holding it on, and I took them both out and it still feels like it's in there pretty good.
Thanks again
Old Jan 2, 2006 | 03:49 PM
restored92's Avatar
after you take the screws out it slides forward over the hood release then you pull back the black tary paper and there you have it the screws
Old Jan 2, 2006 | 04:24 PM
tagta189's Avatar
those kick panels have I think 2 screws buried in the carpeting that are usually totally invisible.Kind of feel around for them,you won't see them.
Old Jan 3, 2006 | 11:36 AM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
If they are factory pins the top pin will be mushroomed on the one side.
you will need to use a die grinder or a dremel to carefully grind the mushroomed part off and then it will pop right out
I used a hammer and a screwdriver
ktthecarguy
Jul 5, 2020 11:46 AM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
3rdgenparts
Aug 8, 2015 07:09 PM
