Door Swap
Old Jan 2, 2006 | 12:24 AM
IROC in SoCal's Avatar
Door Swap
Does anybody know if a door on a 1986 Berlinetta will fit a 1987 IROC Z28?
Frank
Old Jan 2, 2006 | 01:10 AM
PhAnToMs's Avatar
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
yes might have to make holes for gfx
Old Jan 3, 2006 | 08:34 PM
Thanks. Are the door dimensions the same? I have access to a parts car and would like to use the passenger side door. My parts car is a 1986 Berlinetta.
Frank
Old Jan 4, 2006 | 12:02 PM
johnnyq5021's Avatar
Car: 85 TA
Engine: dont wanna talk about it
Transmission: 700r4 for now
dimensions will be the same also
Old Jan 4, 2006 | 12:30 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
i plan on swapping a new driver side door on my car...as for all the electronics that go into the door..the power locks and all...Can i unplugg this stuff from the harness somewhere? or m i gunna have to cut the wires and crimp that onto the new doors harness?
Old Jan 4, 2006 | 08:30 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Just did a door swap, and it was pretty straght forward, the wires unplug inside the door and then just pull them out throgh the door flex grommet, they'll plug into the other as lond as the other door has the same options, otherwise you'll run into a whole other project of swapping the internals into the good door an easy feat in no way.
Took me about 2 hrs with the right tools, also the drivers side door has an obstruction blocking the bottom hinge bolt, it's just a power block that can easily be removed should only take a little prying. I used S-shaped gear wrenches on the top hinge and it made things a hundred times easier. Good luck.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
