question about cleaning interior materials...
Old Jan 14, 2006 | 12:57 PM
Trah84Z's Avatar
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
so i scored at the junkyard today and got a headliner, sun visors and kick panels in this black felt type material. there aren't any stains on them, i was just wondering what i could use to clean them up a little, or i could just vacuum them probably.
i also got the metal holders for the front speakers (under the dash pad) and the little center piece. they look like they are aluminum, what could i polish these up with, it looks like a little rust is starting to form...
i got all of this plus some air vents and the dome fixture for $39...awesome...
Old Jan 14, 2006 | 01:09 PM
91rsowner4life's Avatar
Car: 1997 S10
Engine: 4-Cyl 2.2 Liter
Transmission: Automatic
Re: question about cleaning interior materials...
um aluminum does not rust. but aluminum does get oxidation on the surface. but Mothers makes aluminum polish.
Old Jan 14, 2006 | 01:14 PM
MikeDirntRulez's Avatar
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
DONT CLEAN YOUR HEADLINER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I bought my car with a perfect interior. Headliner was in perfect condition, then I decided to try and clean a spot off on the headliner. Well, it turned into a small sag, nothing big.... 6 months later the whole headliner is drooping.
Biggest mistake of my life. HUGE HUGE WARNING: DONT SPRAY ANYTHING ON YOUR HEADLINER, YOU WILL MORE THAN LIKELY DAMAGE THE ADHESIVE ON IT.
Old Jan 14, 2006 | 01:25 PM
Trah84Z's Avatar
Engine: 305 V8
ok...so i'll just vacuum the headliner and kick panels...thanks for the heads up...
so i'll probably just use aluminum cleaner on the speaker holders...
Old Jan 26, 2006 | 05:32 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
i hope you didnt do it already with the interior the vacuum could pull the liner apart as well good luck
Old Jan 27, 2006 | 01:06 PM
SKFengineer's Avatar
Car: '87 IROC (TPI 350), '01 Corvette, '
Engine: '90 Corvette 350, blueprinted and b
Transmission: 700 R-4, with stage 2 shift kit
DON'T VACUUM THE HEADLINER
The title says it all... If you vacuum the headliner you will pull the fabric away from the glue and foam behind it. The whole thing will be in your eyes in a number of months... Best thing if it's not stained is to just brush it lightly with a softer bush if your trying to knock dirt off.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
