My A/C Delete Process - 24 Images inside
Old Jan 22, 2006 | 02:30 AM
Psycho_91Camaro's Avatar
Car: 1991 Camaro RS
Engine: THE LT1 SWAP SHALL BEGIN!!!!
Transmission: 700 R4
Axle/Gears: LSD! =(
Introduction:
Iv'e never taken anything like this out of any car in my 20 years of life... give me a break if I did stuff wrong. Some things I didnt know what to do... I did read some of the posts on here of people taking thier A/C out and putting 1LE delete pulleys in I found the lower pulley very hard to remove and install so It wasnt done. As I read and asked questions I found it hard to follow thier concepts and advice because most people only posted thier finished set up and I wanted more images of the whole process and was very anxious to see images of others doing this, but found nothing. So for the next few minutes I will be showing you fellow third genners how I did it.. laugh if you will but I just wanted to show others that are of my age and have a lack of knowledge on this stuff how it looks like and how I went about doing this, hopefully others will learn not to make the same mistakes I did. Again please acknowledge and understand that I am still a novus.
Heres some pics of my 1LE AC DELETE PULLEYS a water pump and DOORMAN WINDOW motors all from pep boys... except the 1LE delete pulleys of course those I got from GM direct. (ALSO im selling the lower pulley if anyone wants to buy it, ill let it go for $40.00 pick up only)
Different looking window motor
Old Jan 22, 2006 | 02:31 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
So it begins.. I start taking my brothers tools out and getting everything ready.
Old Jan 22, 2006 | 02:34 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I start by removing the canister and bending the $h1t out of the pipes that connect to this thing behind the radiator hahahah
As you may tell, I removed some pulleys before I started. Dont know why...
Old Jan 22, 2006 | 02:40 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I then break the fiberglass housing and pull the ac core out
(PLEASE BE ADVISED! WEAR GLOVES!!!!! THAT FIBERGLASS IS ITCHY AND CAN CAUSE IRRATATION ON YOUR SKIN!) THAT SCREEN ALSO RIPPED MY SKIN!!!
Looks like some birds were building a nest down there...
Old Jan 22, 2006 | 02:47 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I then took off the heater blower by unscrewing the housing off, this is much more easier once the AC canister and core and fiberglass crap are out the way... this is how it looks like when it is removed... much more room!!
Cleaned up the area a little, thenafter begin on the air pump removal and try to see how to remove the lower pulley..
Hmm
This is suppose to go down there.. but where and how do I take off that pulley?????
This appears very strange to me... so I try comparing it to some one elses finished set up to try to get an idea..
Can't figure it out, so I move on
Old Jan 22, 2006 | 02:51 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
I then install the heater box and that aint not easy task either it doesnt match up with MOST of the holes.. so I just screw in the ones that do (Also I forgot to put a gasket around the edges or gasket sealer) and install the blower fan and have a problem with it.. the fan blades are too long so I will cut the $h1t out of them ahaha
Problem:
Solution:
Grab a metal cutting tool and cut the blades to a lower length!! to my surprise it did not weaken the blades and are still extremely stiff.
The fan now fits and life can progress.
Old Jan 22, 2006 | 02:58 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
Hook all the switches and relays together, then I look at all the mess I made.. heheh
Done for now... I still have to completely seal the heaterbox and take that thing out of the front of the radiator.
Old Jan 22, 2006 | 08:22 AM
Demon355's Avatar
hah cool, i want to do this as well...
Old Jan 22, 2006 | 10:05 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Unbolting the top half of the heater box works almost as well as breaking it .
I love my V belt setup, I don't have all that crazy pulley crap to deal with. Either way, nice job, I love the metal finish heater box.
Old Jan 22, 2006 | 10:16 AM
DJCobol's Avatar
Car: '89 Black IROC 'vert
Transmission: 700-R4
Axle/Gears: 2.73 posi
The condenser. Looks good. I'll be doing this shortly when I put headers on my car and get rid of all my smog/AIR crap at the same time.
Old Jan 22, 2006 | 11:21 AM
Slimjim's Avatar
Car: 1992 Firebird
Engine: Under the hood.
Transmission: Behind the engine.
I hope you pulled the smog pump, as the belt will rub against the stub on the front of it, and tear it up. Its only two torx bolts holding in the pump.
Old Jan 22, 2006 | 01:02 PM
Abubaca's Avatar
hehe...looks like you got that closeup of the smog pump pulley from my car!
....keep in mind that's an emissions pulley/pump, not an AC accessory. I'll be honest, I didn't have any trouble removing it. I never gave it a second thought, and to be honest, I don't really know how I did it since it wasn't a problem.
Here's better pic of the delete pulley. Note that it's only held on by two bolts. That should make life a little easier.
Attached Thumbnails My A/C Delete Process - 24 Images inside-serpantinepost.jpg
Old Jan 22, 2006 | 01:45 PM
85_Camaro_Kid's Avatar
Car: 1985 Chevy Camaro
Engine: 350 2-bolt
Axle/Gears: 10 bolt, 3.23 posi
WHere can I get that big metal box that holds your blower motor?
Old Jan 22, 2006 | 03:49 PM
Abubaca's Avatar
Ebay or the classifieds.
...but if you can find one in a junkyard it'll be a LOT cheaper. I've seen 'em go on Ebay for over a hundred.
...Oh, and cutting the blower fan DOES WORK. I tried several things that worked, but I'm currently running a cut up fan and it works FINE. PLENTY of air flow.
Old Jan 22, 2006 | 04:22 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I don't know if cutting up the blower fan was absolutely needed.
when I did the whole ac delete to get my motor to fit I made a thick spacer out of a couple of thin pieces of wood and gasket material.I made it about half an inch thick.
I also used weatherstripping to seal up the heater box.
Old Jan 22, 2006 | 04:50 PM
Car: 86 T/A
Engine: HSR 355
I also cut my fan. I have an extra blower motor with the smaller fan, BUT it used a different connector than my car so rather than rewire I decided to just cut the blades down. You can't merely swap the fan blades, you need the non-AC motor and fan blades together. Cutting seems easier than using some wood spaces IMO.
Old Jan 22, 2006 | 05:09 PM
Abubaca's Avatar
I tried the spacer thing too, but I had an extra fan, figured it was worth a shot. It worked just fine.
Old Jan 22, 2006 | 09:22 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
I have been looking for a blower box and can find one for a resonable price, and I dont know if they made many camaros without airconditioning let alone find one at a junkyard. Does anyone know if I could me a delete box out of my old box?
Old Jan 22, 2006 | 10:09 PM
Car: 86 T/A
Engine: HSR 355
S10s in the late 80s/early 90s used the same non AC boxes.
Old Jan 22, 2006 | 10:37 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
S10's hmm ok .. any other cars ? Yeah junkyard comes in mind too
Old Jan 23, 2006 | 12:53 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
OK thanks, that will pry help, did they make many non airconditioned s-10's?
Old Jan 24, 2006 | 03:42 PM
1985WS6transam's Avatar
Car: 1988 Firebird Formula
Engine: 388 Carb
Axle/Gears: 4.10
I just did the box swap and cut the fan... but my question is how do you hook up the wiring?? Is it only one plug? I tried it and my fan doesnt work at all.
It was working before the swap though. any advice??
Old Feb 2, 2006 | 06:43 PM
nick05's Avatar
Car: 1987 camaro
Engine: 358
Transmission: TH350
Can you be more specific on the year of the s-10 heater box?
Old Feb 3, 2006 | 08:56 AM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
If you are not going to use that lower pulley, Ill give you $40 shipped for it.
I can get it for less than $40 plus shipping from GMPartsDirect.
Old Feb 4, 2006 | 04:04 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
What im planning to do now is. Rebuild the 305 SELL THAT and buy an LT1 and rebuild/bore/port that. So I'll sell the 305 with the ac delete pulleys.
I'll let you all know when that happends.
Old Feb 4, 2006 | 10:26 AM
stocker85's Avatar
good article,,,,,,did your brother smack you around for throwing his tools all over the place
Old Feb 19, 2006 | 04:13 AM
Car: 1991 Camaro RS
Axle/Gears: LSD! =(
nah I cleaned up everything and put away all his tools before he came home!
Old Feb 21, 2006 | 08:40 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
The S10 heater box looks similar, but is NOT the same! it will not directly replace the f-body non-a/c heater box. You can buy a blower motor fan blade for a non-a/c f-body at a regular auto parts store (it's similar to the a/c version, only shorter). I checked at advanced auto and they had one for about $18 in stock. I got one from a junkyard instead.
For the smog pump removal, on mine, you have to remove the 3 bolts holding on the pulley part first. Wedge a screwdriver between two of them and loosen the third, repeat until all 3 are loose and then remove completely. Next, remove the two bolts holding the smog pump to the bracket. At this point, you can either use the delete pulley OR you can simply go to a shorter serpentine belt and bypass it altogether. There's a great post showing the new routing without it and the exact length of the belt. I can try to find it again if anyone wants the link, or i can take a picture of mine.
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
