Shift Knob Beating me up!
Old Jan 28, 2006 | 08:07 PM
zrated57's Avatar
Shift **** Beating me up!
I just bought a shift **** on ebay from a 90-92 Camaro and I have an '85 Z28. I know this question has been asked before, but how can I make it fit and work correctly. Is there a trick to make it work easy? THANKS
Old Jan 29, 2006 | 07:56 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Take off the old one and install the new one.
Old Jan 29, 2006 | 09:21 PM
MNformula350's Avatar
I assume you have an automatic, your 85 has the round ball **** shifter right? and to put on the other style ****, you need to change the entire shifter assembly. the proper mount for the later style c-clip is not on your current shifter.
Old Jan 29, 2006 | 10:30 PM
zrated57's Avatar
Yeah, it's an automatic. Do you know where I might be able to find the entire assembly? I looked on ebay, but without luck. Thanks.
Old Jan 30, 2006 | 08:25 AM
white91formula's Avatar
Car: 91 formula
Transmission: t5
junkyard is your best bet, find yourself a pick apart
Old Jan 30, 2006 | 08:54 AM
Jim85IROC's Avatar
Whoops. I thought you could mount either style on the same shaft.
Old Jan 30, 2006 | 07:09 PM
Jim - I am still learning new stuff everyday too.
zrated57 - I am actually swapping out the other style shifter from my 88, to the round ball style eventually. When I finally get around to it ( I have had the parts for a few months ), I will check and see if you haven't already got one, I can send you mine for the cost of shipping.
Old Jan 30, 2006 | 08:35 PM
zrated57's Avatar
MNformula350 Thank you very much, that would be great. If I can use the newer style shift **** from a 92 Z28 Camaro then I will take it for sure, because that's the **** I bought. Let me know when you have it ready and the cost. Thanks again. My e-mail is zrated57@hotmail.com.
-ERIK
Night rider327
Feb 25, 2016 09:50 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
