Window regulator rivets
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have done a search for this and all I see is that they are 1/4" rivets. In the article on the main page it says something about "peel" rivets. Are these special or something? If they are regular rivets what length are needed? I have been looking at new ones and they seem to have different lengths.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Peel rivets open up like a banana peel when they're installed, instead of just mushrooming like a normal rivet.
Engine: 383 Carb
Transmission: 4L60
Probably, if you've got a tool that can install a 1/4" rivet. I don't have power windows in my thirdgen but when I do a window motor on my other cars I usually just use nuts and bolts instead of messing with rivets.
Car: 92 Firebird
Engine: 4.8 LR4
Ok thanks. I just wondered, I am just going to buy a large rivet gun as they are fairly inexpensive. Actually I need this to install the arm rest bracing onto another door. I have panels from my 88 GTA that I want to put in my 91 GTA and everything uses the same rivets.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by scooter
Can I replace them with regular rivets then?
a local glass installer showed me that trick one time... im not sure about our cars, since we have thicker stamped steel inner skins, but on some doors, you need to use washers with regular rivets since they'll put too much stress on one area and loosen over time.
I usually use bolts with neoprene locknuts, that way they'll stay tight without exerting too much pressure on your glass and breaking it, werks great
.HTH
gixxer92
May 18, 2017 11:20 AM
Royal_Z
Sep 30, 2015 08:45 PM
