power windows
Old Feb 11, 2006 | 07:54 PM
sam's Avatar
sam
power windows
I did a few searches but couldnt find anything....
I changed my driver side power motor in the summer due to it being so weak. well I decided to open the window after not opening them for a few months
I got it going down and a 1/4 way down it had a crack sound. then it continues dow to 1/2 way and same thing. When I was all the way down, I could not get the window to lift past 1/4 level. So I got mad and pull on the window as i pushed the switch...
The window felt lose, it had play, up, left & right.
I had to then remove the door panel to get a better view on the mechanism. Can really se anything wrong. It is lose though. Not the motor mounting but the arms that have "wheels" attached to them and run in a rail....
I kind of used wd40 on the rail in the summer. Should I have used grease?
What do you recomend I do?
Finally got it to close and reinstalled the door panels while I figure a solution.
Old Feb 11, 2006 | 10:12 PM
sgt0704's Avatar
Car: 91 camaro rs
Engine: 305 tbi
Transmission: 5 spd
Axle/Gears: what ever stock is
i did the same swap on the pass door. make sure the wheels are reinstalled correctly.
Old Feb 12, 2006 | 12:22 AM
stitchop's Avatar
Car: 91 firebird
After you fix it, Definitely use grease!!!!!
WD40 is a solvent, it will dissolve any grease you had left, then it will evaporate and there is no lube for the mechanism.
Old Feb 12, 2006 | 03:26 PM
sam's Avatar
sam
THanks guys,
The wheels were put in correctly as it worked fine until recently.
I will add grease once it gets warmer over hear.
Does anyone know if there are repair kits, with the wheels and such?
Thanks,
Sam
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
