What to do about antenna?
Old Feb 8, 2006 | 08:24 AM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
Ill be repainting my car soon, and doing a few body modifications, i would like to shave the antenna as it sticks out like a sore thumb, is there anyway to still be able to get FM radio reception without the antenna?
Old Feb 8, 2006 | 10:05 AM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Transmission: Th-400 w/ Manual valve body
Axle/Gears: 4.10 Richmond gears
I plan on doing the same thing. I kno crutchfield.com has some cool interior antennas. like a car alarm antenna. Do a search.
Old Feb 8, 2006 | 12:14 PM
92MaroRS's Avatar
I just talked to Crutchfield and they said they dont have any interior antenna's.
Old Feb 8, 2006 | 01:41 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Check with your local Glass shop, some of the 82-85 Berlinettas used a Windshield Antenna... I think it may have been on the S/E too, but not positive. Also some exported cars to Europe had the W/S Ant.
EDIT: I just called my local Glass Shop, and they can still Get the Windshield WITH the antenna, $227 INSTALLED!!! That includes new moulding too
John
Old Feb 8, 2006 | 04:22 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Umm... Than explain this! Mwa,ha,ha,ha
J/K I don't know if they still sell these, but i'm looking to buy one
http://www.crutchfield.com/S-r2adq0j...p?i=12044UA200
Old Feb 8, 2006 | 04:23 PM
oxiderush's Avatar
Car: 90 firebird
Engine: 350 5.7L
Oh yeah, here's another good thread on this;
https://www.thirdgen.org/techbb2/sho...hidden+antenna
Old Feb 8, 2006 | 05:34 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
hey summit has a good one let me see if i can get the part number for you but look on summit it is a box you just hide inside adn just needs 12v to it and works great for about 50 bucks
Old Feb 8, 2006 | 06:47 PM
MNformula350's Avatar
I have read that you can put the antenna up under the dash, and the reception is just the same as if it was out on the fender. i can't verify that though. I plan on trying it when my Formula gets reapainted next year, I am shaving it off of the fender.
Old Feb 8, 2006 | 07:19 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
mnformula350
i recal reading that too. i can't remember who it was, but he drilled a small hole in some plastic under his dashpad and mounted the antenna to it so it was going along under his dash pad. then he put some foam around the end so it would not make a racket under there. i always figured i would do that one day. but i think i am just going to convert to a power antenna. more GTA like anyhow.
Old Feb 8, 2006 | 08:13 PM
jay92,85,79's Avatar
Car: 85z28,
Putting it under the dash pad work just fine. Just find a antenna that has a small base to it..
I have heard of people puting them in there headliners to. But more of a pain to do
Old Feb 9, 2006 | 03:59 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Radio shack sells ones that go inside the car.
Old Feb 10, 2006 | 02:57 AM
Night rider327's Avatar
Car: 1988 Camaro
I shaved mine off and just put it under the dash (not the pad). Took the pass. side panel off above where pass. feet would be.
Stuck the antt. up through there, behind consol and went on the driver's side of car and pulled antt. through and pushed it up and over the steering cloumn.
With it toching the coulmn my reception was poor, but then I just put a pc. of thin plastic bettwen antt. and coulmn and it fixed it.
reception aint quite as good as it was with antt. on the fender.
If on the fender was 100% then where I have it now is about 85%
But I do live out in a hick town back in the sticks, so most of the local FM ch. are 40-70 miles from me
Old Feb 10, 2006 | 04:20 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
If I remember right both Kandied91Z and redraif left the antenna hooked up and slide it up under the dash. That's what I've done with mine but the welding isn't done to fill in the fender, so unlike there's mine looks like ****.
edit: apparently someone else did it too!
Old Feb 12, 2006 | 03:53 PM
coolcamaroZ28's Avatar
Car: 95Z / 91Z / 10SS
Engine: LT1 / LB9 / LS3
Transmission: T56 / 700R4 / TR6060
I decided on a power antenna. I got the one from JC Whitney b/c they have the remote mount one so it can fit inside the fender...
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
scottmoyer
Sep 7, 2015 07:06 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
