Removing T-Tops
Car: 1992 Firebird
Engine: 305 TBI
Removing T-Tops
I just purchased a 1992 Firebird. There is no key for the t-tops and they are in the locked position. Any suggestions about how to remove them?
Car: 1985 Trans Am
Axle/Gears: 3.70
I'm assuming you tried the door key? Should be the same key for the doors, trunk, t-tops and cargo storage.
Otherwise you're in for some fun. I'd probably call a lock smith.
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Its been awhile, but I remember a guy removing t-tops by taking the plastic cover off and then you can see the rods. You should be able to move the rods enough to get the top off, atleast he did.
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: soon to be 3.73's
It's been a while but i think you can take the plastic piece off, and drill out the rivets that hold the lock. Then, just open it. I did this a long time ago, so i might be wrong.
Car: 91 firebird
If the door key does not fit, go to a GOOD locksmith. If you can not afford a locksmith, just leave them on until you save up enough money to pay one, you do not want to hack up your t-top panels. Just my
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I +1 the locksmith.
The pin that keep the t-top on goes thru the panel so you cant remove it and access the lock
The lock aint complicated at all
Same thing as your lil rear cargo area lock
Locksmith or a paperclip, not a major deal
Theives get in by peeling your window away until it pops off track and removing the t-top to get to the door lock, or just go strait for the lock if they're skinny enuff
Locking the t-tops was a feature because theives used to rob the t-tops themselves, not necessarily security of the car's contents
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Three screws and the trim panel is off of the top itself. Then you can peak and see what needs to be done. T-tops are certainly cheap enough, I even have a set in great shape for $60. If they aren't in good shape you could just cut the locking bars and pull each top off. Also, alot of these t-tops are not original to the car so the door key may not work.
Car: 94 Camaro Z28
Engine: 5.7L
Axle/Gears: GU5 3.23
My t-tops were so easy to pick with some basic tools that it was almost funny. I'm very inexperienced with lock picking, but it took me less than 1 minute per t-top to get mine off.
Car: 1987 Camaro IROC-Z
Engine: LB9
i removed a set of t tops at the junkayrd once by taking off the handle with a torx 15 or 20, then drilled the rivit ouf and pulled the lock cyl out and the t tops were liberated of the parts car.
Car: 98 z28
Engine: ls1
Transmission: t56
"i removed a set of t tops at the junkayrd once by taking off the handle with a torx 15 or 20, then drilled the rivit ouf and pulled the lock cyl out and the t tops were liberated of the parts car."
That's what i said, or was trying at least. Then to get it to lock, you just need to run a bolt or screw threw the place for the rivet. If someone really wants in your car, the t-top being locked will not stop them.
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
I love it when people try to tell me my profession is easy! Paper clips's and you had them off in one minute. You are lieing thru your finger tips.
It has taken me many years to learn how to pick the GM sidebar cylinder with any kind of regularity even with the proper tools(rake and tension tool). Every jackass I have met that has told me paper clips work has never been able to pick even a basic padlock in front of me.
Do not discount my profession it funds my 3rd gen habits.
Car: 91 firebird
I have listen to a lot of people with their "couple of paper clips" crap, but when someone locks their keys in the car those paper clip people end up with bent clothes hangers down the door crack trying to reach the keys, scratching up the paint and ripping the weather stripping.
Car: 94 Camaro Z28
Engine: 5.7L
I don't understand why you take it so personally, especially when in all reality no one here told you your profession is easy.
I can't be sure, but perhaps it makes a difference that these t-top locks have been used or even unused for 14 - 24 years.
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Re: Removing T-Tops
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
