LED in Hvac fan switch
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
O.K. I was a little board today & i always have trouble seeing what position the **** is for fan speed during night hours.So i drilled thru the **** with a 1/16 drill.Mounted a green led in the back of the ****.Ran a wire to the hvac lamp( LED).So they're both on at the same time.The pic makes the led look bigger though.A little overkill, but at least now i can tell the position of the **** in relation to the blower fan speed.
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Cool mod- does your car not have the light specifically pointed at the radio/HVAC controls like the firebirds do?
Car: 1985 Trans Am
Engine: 305 5.0 LG4
Transmission: 700-R4 Auto
Some camaros had a light under the ac vent housing, though i never seen one with them, all camaros i seen have the housing for it there. Others have a overhead lamp in the mirrior but not all have this feature. So when you don't have eithier one your in the same boat as 84 1le.
Thats a cool mod. Never had thought of that, very nice and orginal.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Originally posted by sully91rs
I dig that a lot. How tricky is it to tap into the HVAC lighting?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Car: 1991 Camaro RS
Axle/Gears: Tru-Track posi/Moser axles/4.10
my "mystery" light still operates but it doesnt light too much. it makes the top of the HVAC and stereo unit lighter but thats about it. makes the interior look a bit nicer but doesnt actually seem to have an actual use. maybe 15 years ago it was brighter but it seems pretty dim to me.
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
That mystery light in the pic above reminds me of the fiber optic "light" for the ash tray.Or is there actually a bulb there?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Some,but not all ashtray have them.There is a fiber optic line that runs from the shift indicator housing to the ash tray.The fiber optic line picks up the light from the indicator lamp & carries to the other end in the ash tray.You can see the tip lit up,but not the tray.Its suppose to illuminate the tray in the darkness, but its impossible to tell.Maybe a pic will help.
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
