Anyone ever use Rust Mort to stop/repair rust??
Old Feb 27, 2006 | 11:20 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a lot of rust on my Ohio car...i have a bottle of rust mort laying around but the directions are worn off. any tips advice how to use it correctly? do you need to paint when/if it dries?
also how good is the stuff, actually? ive heard it will dissolve any rust and kepe it from returning... or is it actually that good?
Old Mar 21, 2006 | 06:05 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
anyone at all?
Old Mar 21, 2006 | 06:30 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
http://www.sem.ws/tech_sheet/RM%20TDS.pdf
from
http://www.sem.ws/product.php?product_id=164
Rust Mort is similar to Ospho. It's phosphoric acid (and some other stuff), turns the rust into an iron phosphate, when it dries you can just paint over it.
I've used Ospho before. Works really well, the rust never came back. Try and remove as much of the flakey rust as you can, so it will penetrate to the remaining metal underneath.
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I've used it. I have a bottle at home actually.
It's a phosphoric acid liquid, similar to naval jelly. Just clean the area, spray it on and let it work. After its dried you can wash off the white residue.
Some people say you should keep it wet, use tissue paper or something to act as a sponge on the surface, and also you can just add some water, just keep it wet, so it keeps working. It'll take some time, not just spray and walk away like it says on the bottle. And or scrub it in. Then once all the red rust is gone, you should have clean metal and/or a black coating. Wash it, let it dry. Then you can paint/bondo, whatever. It'll leave a zinc coating to keep it from flash rusting.
Old Mar 21, 2006 | 08:00 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
thanks. i cant wait to use this, i have some rust on the car but dont have time/money/experience to fix it all with new sheetmetal. this will be perfect
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Fireslash
Apr 11, 2016 06:43 PM
FueledSoul
Sep 30, 2015 09:18 PM
tcflint
Sep 27, 2015 05:58 PM
