Where can i find blank door panels?
Old Mar 6, 2006 | 01:17 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
Im trying to find just the backing piece plain nothing cutout. Does anyone know where you can buy this? I want to make my own door panels.
Old Mar 6, 2006 | 01:45 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
1/8" plywood from your local hardware/home improvement place.
Old Mar 6, 2006 | 01:54 AM
f355bird's Avatar
Car: 1985 Iroc-Z
Transmission: t-5
thanks didnt think about that
Old Mar 6, 2006 | 07:12 AM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
dont use plywood, use that stuff they make pegboards out of... forgot the mane of the material.
Old Mar 6, 2006 | 08:08 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
masonite.
Old Mar 6, 2006 | 08:42 AM
stitchop's Avatar
Car: 91 firebird
Not masonite, Tempered hardboard.
Make sure to get the kind that is smooth on both side. It is also water resistant, (but not water proof.) Plus it is only about $10 for a 4'X8' sheet.
Old Mar 6, 2006 | 10:28 AM
Jim85IROC's Avatar
Which everybody, including the guys at Home Depot, will errantly call Masonite. If you ask for Masonite, they'll bring you right where you need to be.
Old Mar 10, 2006 | 08:25 PM
C. W. H.'s Avatar
Car: 1989 Firebird Formula 350
Transmission: 700
Good luck trying to use a staple gun on tempered board/masonite. I made two door panels out of that stuff and it's extremely hard to get staples, etc to puncture through.
Let me know how it turns out and what you used to adhere the material...besides using 3M adhesive spray.
You might be better off purchasing chip board from a Michaels fabrics, etc. I think it's 1/16 so you'll have to stack it and then srpay the 3M adhesive spray to bond them together.
Old Mar 10, 2006 | 08:35 PM
Pocket's Avatar
Car: 91 Trans Am
Plexiglass very thin and 100% waterproof
I used epoxy to glue the material to the back
Old Mar 10, 2006 | 09:04 PM
MattODoom's Avatar
Car: '88 G T/A
Axle/Gears: 3.27 9 Bolt
We are using .090" ABS sheets for our 46 hot rod, were going to see how it goes. You can heat it up with the torch and bend and form it to make whatever shape you need.
Old Mar 28, 2006 | 04:59 PM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
door panels
my question is if your using these other backer materials how are you using factory type plasitc panel clips. What are you using that is easy to use and still be able to take the door panel off without messing up new fabric?
Old Mar 28, 2006 | 05:47 PM
MattODoom's Avatar
Car: '88 G T/A
We are using Velcro. THe door panels is supported by the armrest bracket, speaker and garnish moulding, so the velcro only serves to hold it snug against the metal.
Old Mar 28, 2006 | 06:32 PM
ricktaylor's Avatar
Car: 84z28
door panels
if your using velcro, which is a excellant idea the are you using velcro on the upper piece as well to secure it to the panel? Just wanted to make sure, Ive good door panels but would like to try my hand at making some.
Old Mar 28, 2006 | 06:52 PM
MattODoom's Avatar
Car: '88 G T/A
Sorry, to clarify - this is on a 1946 ford hot rod. The windows have a garnish moulding which is a steel peice that screws in all around the window.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
